Eagle Rods How strong
Old Mar 6, 2007 | 07:08 PM
ryan350z's Avatar
ryan350z
Default Eagle Rods How strong
Hey Guys, well long story short My built motor is toast. Bent valve No biggie, but looks like one of my rings scorn the cylinder wall and dug a groove #5 cylinder. I wondered why that cylinder was lower than the rest on my compression test(before I bent valve on #2 then that cylinder read zero) Ok so I have eagle rods thinking about going to a Darton Mid Sleeve boring out to 100mm sticking with the stock crank, and Eagle rods. Going to upgrade the turbos in the greddy kit to 20gs(thinking about a 10 to 15% increase in flow not much but more). Do you think the eagle rods can handle 650rwhp? I had just under 500rwhp on a mustang dyno on them before.
Ryan
Old Mar 6, 2007 | 07:35 PM
baptist's Avatar
baptist
Never heard of any snapping. They are good quality items.
Although, if your shooting for such high HP, why not spend the little extra on the pauter items, which are time proven to handle anything you can chuck at em.
Im not saying Eagle are in anyway a bad conrod, and they probably can take the power no probs, but if your going to all that expensive, you only want to do it once.
Im running mid 500's and I went Pauter, just to be sure.
Old Mar 6, 2007 | 07:36 PM
JETPILOT's Avatar
JETPILOT
I don't think you have anything to worry about if they are the Eagle "H" beam rods. If they are "I" beam rods I would replace them with H-beam rods.
JET
Old Mar 6, 2007 | 09:12 PM
Dubai's Avatar
Dubai
I know a couple of guys who run them in low 600whp with no problems. for me I wouldnt push them past the 600.
Old Mar 6, 2007 | 09:34 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
I hope you're kidding. The eagle rods will hold pretty much anything a street car can throw at them. Hell...stock motor cars are approaching the 600rwhp mark these days.
Pauters are just overkill for 99% of all builds.
Old Mar 6, 2007 | 10:08 PM
rocks's Avatar
rocks
Domestics run eagle H Beam rods up too 1000whp.
Old Mar 6, 2007 | 10:12 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Definately agree +1.1million
Old Mar 6, 2007 | 10:34 PM
GTM's Avatar
GTM
Vendor - Former Vendor
Ryan
Hey Ryan,
To this day we have not seen any problems with the Eagle rods. If you are worried about them holding up and do decide to upgrade I think our GTM Rods would be a great choice due to their strength a light weight. Here is a little info on them:
Designed in-house, and manufactured from 4340 billet chromoly steel. This material was chosen for this setup over titanium due to longevity, and over a regular forging due to the added strength. Each rod weights 500 grams, and is tested to withstand an equivalent of 2100ft-lb of torque on a 6cyl engine. This unique design allows for an unprecedented compression force/weight ratio, making it the most thoroughly designed and most suitable rod available for the VQ35DE.
Pics:
I hope this helps you out with your current situation, also if you need any help or have any questions as far as your new engine build we machine and sleeves all of our engines in house. PM me if you need any details.
BTW These rods are in our 850+rwhp/800+rwtq Z with ZERO issues
Take care,
-George
GT Motorsports
Old Mar 7, 2007 | 02:33 AM
baptist's Avatar
baptist
^ They would also work
I think any of the 3 listed in this thread would be fine for your requirements.
All good gear.
Old Mar 7, 2007 | 05:11 AM
ryan350z's Avatar
ryan350z
ok great guys, I have the eagle rods in my motor already, and was at just under 500 on a mustang dyno so I have faith.
Todd thanks for the pics and the PM. I have to come up with some cash beofre I can take the next step. Just moved into new house and Fiance needs to buy furniture and etc... So by the end of the month I should be able to swing it.
I think I will just stick it out with the Eagle rods, I have used them In Chevys with more power and no failures.
Old Mar 7, 2007 | 06:27 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
I asked the opinion of our performance machinist here locally. He is one of the most well respected authorities in racing engines here; he builds for the locals and several surrounding cities...
He says the eagle h-beam rods will be plenty for any power that we throw at them in the vq35, he actually likes the eagle the best simply because they are h-beam.
Bottom line... don't use stock rods, we know those fatigue and bend under high power..pretty much ANY aftermarket rod is going to be more than sufficient for the modest numbers most people are running on a street driven engine. If you are staying under 1200hp, you should be fine with any of the options out there...it comes down to personal preference
-TODD
Old Mar 7, 2007 | 06:30 AM
ryan350z's Avatar
ryan350z
-TODD
Thanks Todd.
I had the eagles stress relieved when I had the last motor built. My builder at the time said that they are strong and should pose no Worries.
Old Mar 7, 2007 | 08:40 AM
rocks's Avatar
rocks
Some opinions and results of domestic owners with eagle rods.
http://www.turbomustangs.com/smf/ind...?topic=78836.0
http://www.turbomustangs.com/smf/ind...?topic=71856.0
http://www.turbomustangs.com/smf/ind...?topic=20311.0
http://www.turbomustangs.com/smf/index.php?topic=6604.0
There is more but these guys push thier engines to the limit, so if it works for them eagle rods should work just fine for a VQ. I still dont see why some people hate them. One guy told me once that my eagle rods would break around 450whp, he must of been hitting a crack pipe.
Old Mar 7, 2007 | 08:53 AM
ryan350z's Avatar
ryan350z
Thanks!!!
Old Mar 7, 2007 | 08:54 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Eagle should be fine for most people on here-like already mentioned, but even though I say that I forked out $600 more for the Pauters lol....
Old Mar 7, 2007 | 09:06 AM
rocks's Avatar
rocks
Eagle keeps thier price down by having the rods built in places like china, but the quality control is done here. If they get bad rods they throw them out. When i build me a turbo small block chevy im going to use a full eagle rotating assembly.
Old Mar 7, 2007 | 09:23 AM
minus500's Avatar
minus500
Eagle rods have been popular for a long time and I don't think you'll have any problems with them. I remember some people saying that the only difference between these rods and other "high end" rods is with the balancing tolerances in a set.
Old Mar 7, 2007 | 09:29 AM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
I have Eagle rods for sale, and Arias pistons, Cometic head gaskets, and ARP head studs but just the standard version not the L19 Mid-A guys can pick up or see my threads in the regional section FS:
Old Mar 7, 2007 | 12:10 PM
Cannysage's Avatar
Cannysage
did you over rev or something? dunno how you can bend eagle rods under normal circumstances..
Old Mar 7, 2007 | 12:17 PM
rcdash's Avatar
rcdash
1. Why did the valve bend?
2. Why was the cylinder scored?
3. Was there any issue with the Eagle rods?
Thanks for sharing.
aboodi
Oct 28, 2015 02:07 PM
pr_350z
Oct 1, 2015 05:03 PM
