need a little help...
Old Mar 12, 2007 | 12:45 PM
tig488's Avatar
tig488
Default need a little help...
this is for my 240, not my G, sorry guys, but i trust you guys here on the site more than anywhere else.
i began installing my aem ems today, but it wouldnt connect to my labtop, so i pulled it out and installed the stock/enthalpy ecu back in. i didnt touch anything else on the car, not a single thing.
so, i go to crank the car, and it sputters real bad and white smoke just pours out of the exhaust. my WB starts at 14.5, then slowly drops to 10. i look under the car and there is a HUGE puddle of gas on the ground.
the turbo is full of gas, the exhaust, the wastegate, everywhere theres gas.
i thought, maybe while waiting for the ecu to dock with labtop, the fuel pump just filled the system and flooded it. so i unplugged the injectors and cranked it, it actually ran for about 20 secs then died. so i waited a little while, cranked it up, it did the same thing. after 5 seconds, fuel pours from the turbo manifold, on the rear of the engine. it has the stock fuel return system so the fuel shouldnt be overloading the rail and injectors.
so i pulled the fuel rail, pressurized the system, none of the injectors leaked, i did find that 2 of the large black O-rings had some tears around the edges. i checked all the plugs, and only that rear cylinder had gas on the tip. so i let it all drain. i turned it over with the injectors unplugged several times, tried to crank it again, and the damn thing just pours gas on the ground. for some reason cyl 4 is flooding and the fuel isnt igniting.
WTH can this be? can it be the torn o-rings? or something else. i know the 02 sensors are soaked, along with everything else, its really starting to **** me off.
Old Mar 12, 2007 | 05:15 PM
tig488's Avatar
tig488
got it figured out, thanks guys, lol.
Old Mar 12, 2007 | 05:52 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
What was it?? I'm curious now.. HAHAH~ Glad you fixed it..
Old Mar 12, 2007 | 05:55 PM
tig488's Avatar
tig488
some wires got crossed so the injector was getting a constant current, filling that cylinder with fuel. yikes!
Old Mar 12, 2007 | 08:09 PM
NoahzBurnt's Avatar
NoahzBurnt
good thing u found that.....better thing u didn't take a smoke break!
StateNuke08
Oct 31, 2015 05:01 AM
Mattg350z
Oct 2, 2015 06:51 AM
roberto350z
Oct 5, 2005 08:02 PM
spdu4ia
Nitrous Oxide
Feb 24, 2005 02:37 PM
