Wa;bro install Question
Old Feb 2, 2007 | 08:10 AM
supra crazy's Avatar
supra crazy
Default Walbro install Question
So after reading a couple of threads about installing a walbro pump. Some had said that when installing it yoour suppose to drill a hole in the stock regulator, so your fuel pressure wont be too high. Is this true?
Also I dont remember which thread I read it on, but I found somthing simular about drilling it to .070 or somthing like that in this thread https://my350z.com/forum/showthread....+drill+install
Old Feb 2, 2007 | 08:24 AM
MIAPLAYA's Avatar
MIAPLAYA
Yes you have to drill out the stock fuel pressure regulator and siphon jet or you are going to see 70+ PSI of fuel pressure. I don't have the size the siphon jet needs to be drilled but the drilling of the stock regulator instructions are in the Turbonetics Stage 1 Intall Guide here:
http://turboneticsownersclub.com/tur...icsinstman.pdf
Old Feb 2, 2007 | 11:12 AM
VIZAGE's Avatar
VIZAGE
The the siphon jet needs to drilled out to .070 of an inch. This was told to me by phunk.
Old Feb 2, 2007 | 02:07 PM
THE TECH's Avatar
THE TECH
Do a write up with some pics if you do the install yourself.
Old Feb 2, 2007 | 09:09 PM
supra crazy
Ok thanks. So do I just drill out the siphon jet or do I drill the FPR too? in the TN instructions it only states somthing about the The FPR
I would love too but my sister took my cmera
Old Feb 2, 2007 | 09:19 PM
rocks's Avatar
rocks
Drill the siphon jet and the fuel regulator, you can crush it in a vice the but drilling is better.
Old Feb 3, 2007 | 05:03 AM
VIZAGE's Avatar
VIZAGE
Rocks is right, you do both.
Old Feb 3, 2007 | 07:03 AM
MIAPLAYA's Avatar
MIAPLAYA
Do both...the TN instructions have you remove the siphon jet but per phunk its better to drill out the siphon jet then remove it..
Old Mar 12, 2007 | 11:50 PM
Triple8Sol's Avatar
Triple8Sol
Hey guys, thanks for this thread and the others on this subject. Just installed my Stillen Stage 4 parts this past weekend, including a new Walbro 255 fuel pump. The TN ST instructions had great pics and helped ALOT!
Workshop12
Mar 23, 2020 01:45 PM
Mattg350z
Oct 2, 2015 06:51 AM
Suffolk350z
Sep 13, 2015 02:43 PM
