Gauge Selection
Old Mar 27, 2007 | 05:42 AM
Glex25's Avatar
Glex25
Default Gauge Selection
Hey guys need some input.
I was up late last night racking my brain on how to make this work and can't anyway to make it happen so I have to make a choice.
I need input on which gauges to put to the ride.
I have 4 gauges and can only fit 3 in a A pillar pod so one has to take a back seat.
Here are the selection:
Boost pressure
Oil Pressure
Fuel Pressure
EGT
I'm leaning towards leaving the fuel pressure gauge out for now unless someone can come with some creative ideas on how to make this work.
Does anyone make a custom pod for our sunglass compartment so i can fit 2 more gauges there. If someone does then I can also get a wideband O2 AFR gauge and just be done with everything.
Old Mar 27, 2007 | 06:21 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Ditch the EGT. Replace it with an AFR gauge.
If you are going with a return fuel system, or changing something in the fuel system, keep the fuel pressue amd ditch the oil pressure (or find a good place to put the oil pressure gauge) If not, ditch the fuel pressure, and keep the oil pressure.
You do have an warning light in your dash if the oil pressure drops too low.
Old Mar 27, 2007 | 07:14 AM
THE TECH's Avatar
THE TECH
I agree. Out with the EGT. Fuel pressure would be my next choice to ditch. Just put a pressure gauge in the engine compartment if you want one.
Old Mar 27, 2007 | 07:23 AM
roncfpz's Avatar
roncfpz
+1..........or you could go with a Zeitronix ZT2 for boost, AFR and EGT in one display, then use your pillar for oil pressure and others. Good luck!
Old Mar 27, 2007 | 07:24 AM
Zilvia's Avatar
Zilvia
I thouht we had a OEM oil pressure gauges. or is it a oil temp gauge.
Old Mar 27, 2007 | 09:35 AM
synth19's Avatar
synth19
^ indeed, we already have oil pressure. However, if you want to replace the 3 pods with your own gauges, you have to replace the oil pressure because it's on the same circuit as the adjacent stock gauge. Plus, it looks better if you have all 3 gauges matching.
Old Mar 27, 2007 | 09:49 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
He's talking about putting these gauges in an A-Pillar pod, not replacing the ones in the dash.
Old Mar 27, 2007 | 10:02 AM
synth19's Avatar
synth19
ah, shoot me for skimming as well... I would do boost, AFR, and oil pressure if I had to do three.
Old Mar 27, 2007 | 10:33 AM
Glex25's Avatar
Glex25
Sorry guys I should have given more info.
This is a 05 G35 Coupe with the Rev-Up motor, we don't have oil pressure gauges like the Z's.
I will be installing the APS TT kit w/ 500cc injectors, bigger fuel pump and fuel return system.
https://my350z.com/forum/showthread.php?t=247293
Old Mar 27, 2007 | 10:34 AM
Zilvia's Avatar
Zilvia
oh that explains a good bit then.
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
