Discharging A/C
Old Apr 3, 2007 | 04:41 PM
willyd6869's Avatar
willyd6869
Default Discharging A/C
How the hell do I discharge the A/C without dying? I am trying to install my Turbonetics line.
Old Apr 3, 2007 | 05:15 PM
VIZAGE's Avatar
VIZAGE
Take it to a shop that does AC. This is the only way to truely get all the old out and new charge back in. I was only charged $89 for them to recharge the system. I knew the guy so he didn't charge for replacing the line which doesn't take but 5 min. to replace, if that.
I'm not going to go into to much detail, but there is a high and low line for the AC sysytem on the driver side. One is in front of the brake reservoir brake cover to the lift and the other under the brake reservoir cover. There should be some plastic caps with the "L" and "H" letter. This is were you vent. Which is purely safe for the atmosphere. The car will also have to be cranked and AC run to get all out and in for there's some in the compressor too.
But you won't get it all out this way. So just do it right and take some where.
Old Apr 3, 2007 | 05:16 PM
jaida86's Avatar
jaida86
definatly take it to a shop. we did it in one of my classes and i wouldent attempt it on my own even having gone through it multiple time yet.
QuadCam's Avatar
QuadCam
go to an A/C shop.........
have them discharge the line, then have them swap the line, and then recharge it!!!
Before I went to the A/C shop, I got all the "crap" out of the way and made it really simple. I think I was charged about $75.
Old Apr 3, 2007 | 05:52 PM
willyd6869's Avatar
willyd6869
how did yall uninstall the old line and install the new Turbonetics line?...the round fitting seems confusing
Old Apr 3, 2007 | 06:16 PM
Dirty Dave's Avatar
Dirty Dave
Discharging yourself can get really messy, I removed my a/c last month. Def recommend taking to a shop because you need a special tool to properly remove the a/c line fitting without messing it up.
Old Apr 4, 2007 | 06:51 AM
QuadCam's Avatar
QuadCam
The tool is cheap; any auto parts store will have it. probably around $5......
but you are going to get pressurized green slime all over your car/engine bay!!!
Old Apr 5, 2007 | 05:59 AM
willyd6869's Avatar
willyd6869
what is the tool called?
Old Apr 5, 2007 | 08:48 AM
QuadCam's Avatar
QuadCam
an "A/C diconnect tool."
check your PMs...I sent you a link.
OdesiTT
Sep 30, 2015 10:47 AM
Daytona Blue Z in Bo
Jan 27, 2004 04:58 AM
ForceInduction
Dec 11, 2003 06:52 AM
emu29
Jul 16, 2003 07:51 PM
