First test with the Vortech cog system
Originally Posted by Audible Mayhem
nice man, what kinda numbers did all that high boost put down with your blower...??
hey kevin, hit me up next time you are on aim, i am thinking about unpluging the VCT or actually feeding it full power so it stays open.
let me know your research so i can figure out some stuff...
Originally Posted by Gman2004
Wow, 21psi! I can't wait till you get a new EMS. Congrats!
How could that high psi only make 389whp?? You think timing threw the whp numbers? GL on ur build.. Ill be attempting something like this in the next few wks with the procharger.. We SC owners must step it up.. Im tired of SC being left behind..
Originally Posted by booger
I had made 430whp on 13 to 14psi on the serp belt stock pulley system [ was driving it at 420whp ] Mustang dyno . I knew it was going to make more then the 16psi that the SS box is capable of controling . So the last few psi on the SS box , I pulled a huge amount of timing so I was at 13 degree's btdc .
Originally Posted by jpc350z
The low power at 21 psi is probably limited by the exhaust restricting flow and increasing the backpressure at the blower ..
Nothing to do with 13 btdc for timing ????
lol..ok
No not saying that...I believe it's a combo.. At 21 psi the exhaust must be capable of flowing one huge CFM or it becomes a restriction to flow and ups the outlet pressure of the blower..
as far as boost . I got one loggged run in to 6150rpm...crazy *** boost this thing is putting out .
old psi.......... rpm .................new psi
................3000 ..................4.1
4 .............3500 ......................5.8
7 ...............4500 .................10.5
9 ..............5000 ................13
12 .............5500 ............15.1
13 .............5900 .................17
slipage ........6150 ................18.1
I spun off all the teeth on the small cog belt thats on the blower it self . Not good ....lol . Looking for a stronger Gates Poly-chain 600 mil. belt . If I cant find one I may end up going to a bigger pulley on the blower itself and be satisfied with what that ends up with . I was going into this just wanting to get to redline with the boost I was making
just to add to the above post .
this really does show that the serp belt was [is] slipping all the time with a stock system . Im pretty sure that hte serp belt starts to slip alot sooner than any one thinks . If you go to Vortechs web site and calculate the blower speed with the SQ trim . And the fact that you can only make 11-12psi spinning past the rpm suggested by Vortech . It can only lead you to believe the blt starts to slip in the lower psi range .
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
