boost gauge install
Old Apr 11, 2007 | 06:55 PM
sabrefanpc's Avatar
sabrefanpc
Default boost gauge install
I searched for a while, but couldn't find anything helpful.
Can someone give me some tips as to how to install a boost gauge? Specifically, where should you run the hose and where is the best place to splice in?
Old Apr 11, 2007 | 07:11 PM
MIAPLAYA's Avatar
MIAPLAYA
Run the source line to the nipple on the plenum. If you have something else tapped there tee into that tap. Aside from that the wiring etc should be laid out in your install guide for the boost gauge.
Old Apr 11, 2007 | 07:17 PM
sabrefanpc's Avatar
sabrefanpc
sweet, how should I run the source line through the firewall?
Old Apr 11, 2007 | 07:52 PM
MIAPLAYA's Avatar
MIAPLAYA
Theres a rubber gromet on the passenger side under the plastic trim around the battery. Cut a hole in the grommet and run the line through it.
Old Apr 12, 2007 | 01:27 PM
sabrefanpc's Avatar
sabrefanpc
thanks a ton man!
Old Apr 12, 2007 | 04:24 PM
MIAPLAYA's Avatar
MIAPLAYA
thanks a ton man!
No worries...
codek
Sep 28, 2015 03:03 AM
