Oil cooler...or just oil pan spacer?
Old Apr 13, 2007 | 06:59 PM
billy17425's Avatar
billy17425
Default Oil cooler...or just oil pan spacer?
At which point should you consider an oil cooler?
Old Apr 13, 2007 | 07:13 PM
Eazzy's Avatar
Eazzy
Living in Mass. and running a turbo, Its your call. Living in Mass and running a SC, it wouldnt hurt. Both senarios are based on Hi way driving, if you are in stop dead rush hour traffic often in the heat of summer, then I would on SC,Turbo, and even NA.
Im a firm believer in covering my butt as far as unforseen situations----What if you broke ur Water pump belt and had to haul *** to the next stop ? Cooler oil may save ur motor, and something else that may is that extra qt of oil in that larger pan.
Plus the pan is a convenient place to put that sending unit for the oil temp gage that every hi performance car needs. < IMO
Old Apr 13, 2007 | 07:19 PM
Eazzy's Avatar
Eazzy
I might add, Due to competitive pricing, Auto manufacuers tend to give you JUST what u need under ideal conditions with little margin for error---Oil capacitys, Radiator sizes, Oil cooling components,PS/Auto trans fluid capacitys,Grounding wires, Starter/Alt sizes, stock clutch sizing, etc.etc. Its a good car owners job to improve on the existing
Old Apr 13, 2007 | 07:23 PM
kwiker's Avatar
kwiker
Shift_Dorifto
I like the way this guy thinks.
Old Apr 13, 2007 | 07:59 PM
Devil Z's Avatar
Devil Z
Old Apr 13, 2007 | 10:59 PM
Cannysage's Avatar
Cannysage
it is important, but it's way down in my 'must' have list. Oil pan is a few line above the cooler on that list.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
