extreme turbo kit from aps
Old Apr 19, 2007 | 09:48 AM
KempieZ's Avatar
KempieZ
Default extreme turbo kit from aps
what turbos are used in this kit? Cant find it. Wanna buy them. I have the standard kit, but already have bought external wastegates and extreme fuel system. Now the turbos and I am ready to go because the old ones are broken with the blown motor. Should have bought the extreme kit in the first place but I didnt need it a year ago.
Thx
I will post some pics when the built is finished. The block I received from injected performance is amazing!
Old Apr 19, 2007 | 10:11 AM
westpak's Avatar
westpak
SFZCC
Unless your kit is one of the newer ones you will also need the manifolds.
The newer kits have manifolds that will work with both kits.
Old Apr 19, 2007 | 12:40 PM
TENGAI's Avatar
TENGAI
GT30's vs. the GT25's in the standard kit. They're internally wastegated turbos that APS weld caps so that they can use the existing piping from the standard kit + their external wg setup.
Old Apr 19, 2007 | 12:41 PM
05blu350z's Avatar
05blu350z
is the extreme kit really worth it?
Old Apr 19, 2007 | 03:25 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Physically, they have the same dimensions as the reg APS TT. The AR is different on the exhaust housing, but that's the only difference I can see with the naked eye.
Westpak....you know anything more?
Old Apr 19, 2007 | 05:01 PM
westpak's Avatar
westpak
SFZCC
Not sure what if you are questioning my comment about the manifolds or asking if there is more information on the turbos. But yes physically the turbos should be the same in turbine mounting flange but the new manifolds have a second port for the wastegate and when using this manifold with the standard kit you plug that port with a plate.
Old Apr 19, 2007 | 05:10 PM
Sharif@Forged
Forged Performance
No, I was wondering if your really did know anything more about the turbos used, becuase I don't know much at all about them!
From everthing I can tell, the physical outside dimensions are identical to the reg APS TT turbochargers. They AR is larger on the APS TT extreme, but I can't see anything else that stands out.
Old Apr 19, 2007 | 05:30 PM
westpak's Avatar
westpak
SFZCC
Ah, no sorry, other than they look similar in size I don't have any other info, I guess I shold have placed them side by side, next time
Old Apr 19, 2007 | 07:33 PM
abyss's Avatar
abyss
Not enough people have them to tell yet, but for what you get for the price I would see it as worth it.
Old Apr 20, 2007 | 06:11 AM
al v's Avatar
al v
And what about the Garrett GT3071R with small intake ????? would fit with the aps kit????
Old Apr 20, 2007 | 10:25 AM
KempieZ's Avatar
KempieZ
I have a newer kit with the new manifolds and the 3.5 DP . I already bought the tial external wastegates but I am planning on running a bigger turbo setup. Gt 30 would be nice. Which turbos fit on the kit and the car? there is not a lot of space. Thx
Old Apr 20, 2007 | 10:26 AM
GSoccer24's Avatar
GSoccer24
GT30's
giggity
Justin100
Nov 29, 2015 03:58 PM
