check engine light issue
Old Apr 29, 2007 | 05:07 PM
billy17425's Avatar
billy17425
Default check engine light issue
ok so i started doing some of my turbonetics turbo kit....i put in the new fuel pump and rc440cc injectors...i put everything back together including the intake to make sure thats all working right i put the car on, ON and checked for leaking fuel non....so i start the car to make sure its all working it starts and seems to be runing fine just it has a check engine light. My question is is this normal to throw a check engine from this or did i mess something up?
Old Apr 29, 2007 | 05:26 PM
fklentz's Avatar
fklentz
Check the code, how are you controlling the larger injectors? You think it may be running rich?
Old Apr 29, 2007 | 05:31 PM
VIZAGE's Avatar
VIZAGE
I wouldn't say it's normal but it happens. Did you have the reflash done or are you getting it tune very soon? You need to find out what the code is and go from there.
My light came on about half month later for a O2 sensor on the passenger side manifold. Nothing serious but it keeps coming back every so often and I just keep resetting it. But yea, have that checked as soon as possible. Do you have any other gauges installed to monitor other vitals?
Old Apr 29, 2007 | 05:32 PM
billy17425's Avatar
billy17425
all i have is the fuel stuff in and no its not tuned yet im ordering utec tomorow...im hope its a running rich code or something simple
Old Apr 29, 2007 | 05:41 PM
VIZAGE's Avatar
VIZAGE
Well that being the case, I wouldn't run it no more. You check for leaks and there are none. So that's one less problem to have. Just get the Utec and get it tuned. In the mean while go over everything several times to make sure it's up to par. I went over mine many times and Devon at Forged still change some things for me (well appreciated) that needed to be done a little better.
Keep us updated?
Old Apr 29, 2007 | 05:49 PM
billy17425's Avatar
billy17425
will definatly keep you guys updated...will make a new thread ethier tomorow or the next day as my progress thread and to share my experiences with the kit and such
Old Apr 30, 2007 | 04:10 PM
fklentz's Avatar
fklentz
My point was that with a "Stock" ECU it thinks it has the "Stock" injectors. When it senses that it's running rich it will try to adjust but it won't be able to. You should'nt put the 440's on until you have a way to properly control them.
Old Apr 30, 2007 | 04:25 PM
MIAPLAYA's Avatar
MIAPLAYA
Exactly as stated. You trying to run 440 cc injectors on a ECU map designed for 260cc injectors. There's no way you AREN'T going to throw a code like that. Get something to control the larger injectors ASAP.
Old Apr 30, 2007 | 05:05 PM
billy17425's Avatar
billy17425
utec is on the way
Old Apr 30, 2007 | 06:08 PM
Gumpdriver's Avatar
Gumpdriver
You are probally throughing (Rich Bank 2). Which is commen.
Old May 1, 2007 | 10:47 AM
QuadCam's Avatar
QuadCam
go get a cheap little actron scanner. I bought one just to keep in my car for checking and reseting.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
kyin
Oct 15, 2015 05:54 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
