Somethings Wrong.....Vortech
Old May 6, 2007 | 02:41 PM
Barzten1's Avatar
Barzten1
Default Somethings Wrong.....Vortech
Got in my car this morning to run errands and upon starting I noticed a bad whine coming from the blower. Not the whine I 've heard from other blowers where it sounds like a rattle can or rocks n the blower. More of a deep whirring sounds. Maybe like the propeller blades were rubbing in there. I pulled the oil feed return lines to make sure they were clean and oil was getting through. Put it all back together and the whine ws still there. Gave it a little gas and black liquid/soot sprayed about 4 feet out of my exhaust. Car choked up a little to. Any ideas? I just got the blower back from Vortech about 3 months ago for service.
Old May 6, 2007 | 02:46 PM
Barzten1's Avatar
Barzten1
Just let the car run for 5 min and gave it a little throttle and more spray came out of the exhaust but it was less. There is no white smoke. Oil pressure was a little less than 30psi at idle
Old May 6, 2007 | 02:57 PM
booger's Avatar
booger
You think with the whine you described it would be the gear set in the blower . But with black soot coming from the exhaust. Im confused . I would also break open the IC pipe right at the BOV and check for oil in the IC pipe .
Old May 6, 2007 | 02:59 PM
Barzten1's Avatar
Barzten1
Will do boss^^^
Old May 6, 2007 | 03:01 PM
VN_350z's Avatar
VN_350z
it looks like you have a bad piston ring, engine oil gets into the exhaust.
Time for rebuilding.
Old May 6, 2007 | 03:04 PM
failsafe306's Avatar
failsafe306
Um, he said NO smoke coming out the exhaust.
Most likely running too rich for whatever reason...bad injector, etc..
I have no idea about the whining sound though.
Old May 6, 2007 | 03:06 PM
VN_350z's Avatar
VN_350z
how did the oil get into the exhaust then?
RA11325's Avatar
RA11325
whats your wideband reading? anything unusual?
Old May 6, 2007 | 03:09 PM
failsafe306
It's probably just condensation, not oil. A busted ring would smoke out his garage in no time flat
When my Z was running too rich at startup, it shot soot and condensation 4-6 feet behind my car.
Old May 6, 2007 | 03:12 PM
booger's Avatar
booger
Exactly...I have two big black spots on my garage door from trying to scale my injectors....the car was 3 to 4 feet away from it .
Old May 6, 2007 | 03:14 PM
booger's Avatar
booger
Barzten....Just pull the cog belt off the blower and see if the whine goes away . SOunds like you may have more than one problem
Old May 6, 2007 | 03:31 PM
Barzten1's Avatar
Barzten1
Will do but car was running fine last night.
Old May 6, 2007 | 03:40 PM
Barzten1's Avatar
Barzten1
no oil in piping by bov
Old May 6, 2007 | 03:46 PM
booger's Avatar
booger
No oil.....cool...so the seals are good in the blower . Did the whine go away when you removed the blower cog belt ?
any CEL lights ?
Old May 6, 2007 | 03:52 PM
Barzten1's Avatar
Barzten1
Always had CEL lights. Gunna remove cog belt now. Thanks Booger
Old May 6, 2007 | 03:58 PM
Barzten1's Avatar
Barzten1
Took cog belt off and no whine. Hmmm.......
Old May 6, 2007 | 04:02 PM
booger's Avatar
booger
Still have the black soot ? Try driving the car with cog belt off , but dont go more than 1/2 throttle and only gradually press down the gas . See what your A/F guage reads .
Old May 6, 2007 | 04:15 PM
Barzten1's Avatar
Barzten1
ok went for a little drive and about 3k rpm my a/f was 15. No more black soot.
Old May 6, 2007 | 04:24 PM
booger's Avatar
booger
Hmmmm...maybe a injector got stuck open and is okay now . Strange !
I would go ahead and try hooking the blower back up . Test it and see if its okay . See if the soot comes back ? If its still has the very loud whine ?
Oh..after you hook the blower back up , make sure the BOV is open and venting the air at idle .
Old May 6, 2007 | 04:44 PM
Barzten1's Avatar
Barzten1
Put the cog belt back on and the whine is still there. Wine is pretty loud. A little black soot still coming from exhaust
