Greddy Turbo installation "MOTOR IN"
Old May 7, 2007 | 04:28 PM
3.6z's Avatar
3.6z
Default Greddy Turbo installation "MOTOR IN"
Hey guys, i'm in the process of installing the greddy turbo kit, but i have a problem getting the driver side turbocharge. The steering shaft is off the steering rack, but it is still blocking the turbo. Also, i already tried to lift the engine about 2", but nothing has changed. Any idea would be appreciated.
Thanks
Old May 7, 2007 | 04:32 PM
failsafe306's Avatar
failsafe306
I dunno man, you just have to kinda "work it in there". Not something that could be described on the forum. When i was doing my APS TT install with the motor in the car, the passenger side turbo was a beyotch to get up in place.
I guess you could try unbolting the front crossmember and lowering it an inch or two.
Old May 7, 2007 | 04:46 PM
3.6z's Avatar
3.6z
well the passenger is way easier than the driver side.
Any idea guys?
Thanks
Old May 7, 2007 | 05:17 PM
imonlykidden's Avatar
imonlykidden
Try PM'n a shop guy. So they don't overlook this thread. i seen it installed before, and it looked like it fit fine.
sorry i couldn't help more.
Old May 7, 2007 | 05:58 PM
3.6z's Avatar
3.6z
bump please
Old May 7, 2007 | 06:03 PM
mario23's Avatar
mario23
Pull the engine out!
Old May 8, 2007 | 04:59 AM
QuadCam's Avatar
QuadCam
check your PMs.
It can be done.........mine was snug, but it goes up there without lifting the motor or anything else like that. try turning it around, upside down, etc...... it'll go!!!
just wait until you get to the front turbo-to-manifold bolts. :-) then, you'll be frustrated!!!
Old May 8, 2007 | 09:02 AM
aj_350z's Avatar
aj_350z
i would say to have pulled the motor from the start. The motor comes out pretty easily, and i would say way less frustrating then trying to install the greddy kit in the car. once the motor is out the kit is cake. Plus with the motor out you can make sure everything is tight to insure there are no boost leaks, because those wastegates are REALLY HARD to get tight with the kit in the car. Im not saying that its impossible, just frustrating and you might need to modify some of your tools.lol But if you've made it this far keep going!!!!!! I will take a look at one of the greddy tt cars that we have here at the shop and see if i cant help you out. good luck
Old May 8, 2007 | 09:34 AM
Kenk2's Avatar
Kenk2
Professional
Originally Posted by QuadCam
check your PMs.
+ wastegate bolts.. Those IMO were the hardest to get on. 5 hours for 2 bolts is crazy.. Never again will I install a Greddy kit without pulling the motor and I had a lift, the works.. If pulling the motor is NOT an option, then I would think about an easier kit..
Old May 8, 2007 | 09:36 AM
9kFever's Avatar
9kFever
is your car a 2006?
Old May 8, 2007 | 05:16 PM
merlin3's Avatar
merlin3
the wastegate bolts are freaking retarded, I had to make some different size length ball drivers just to put thost bolts in. Would be nice if you could put the engine in with the wastegates attached but they hit on the transmission.
Old May 8, 2007 | 06:48 PM
QuadCam's Avatar
QuadCam
no problem with the wastegate bolts for me. They were slow to install, but not a problem. I used a crow's foot and a trick ratchet! I didn't use the allen heads bolts.
Old May 8, 2007 | 07:53 PM
3.6z's Avatar
3.6z
Mine is 03. every thing is now on. the whole process took me about 4 hrs to install both turbos. Alos, there is no need to pull the motor out. the right side turbo is easier than the driver side. i just took off the A/C and the driver side engine bracket. for this side, i used a jack under the motor and took off every thing in this side. Also, do you guys think it is possible to install the WG and WG/dumps with the motor in?
I'll post some pics soon.
Old May 8, 2007 | 08:14 PM
3.6z's Avatar
3.6z
Old May 8, 2007 | 08:20 PM
aj_350z's Avatar
aj_350z
with the dumps it should be easier to do but with the normal recirculating wastegates are very hard to do in the car it is possible but they are hard to tighten. you just really want those to be tight because you dont want a boost leak. make sure you dont forget those compression rings in the wastegate!
Old May 8, 2007 | 08:34 PM
3.6z's Avatar
3.6z
I don't know whats wrong with the pics. i couldn't upload them, but anyway here is the link of where i uploaded the pics.
http://picktech.blogspot.com/
enjoy
Old May 8, 2007 | 09:49 PM
phunk's Avatar
phunk
CJ Motorsports
when i do the greddy turbos with engine in the car, i loosen the turbine housing clamp so that the housings can rotate independant of one another while navigating them in.
Old May 8, 2007 | 11:06 PM
3.6z's Avatar
3.6z
good idea though
Old May 9, 2007 | 03:59 AM
QuadCam's Avatar
QuadCam
oh yeah...I did that too. It makes it nice so you can clock the turbo into the best position.
Old May 9, 2007 | 11:08 AM
3.6z's Avatar
3.6z
I just tried it this morning but it didn't work still the steering shaft is blocking the way.
