vortech FAQ: read this before asking vortech questions
Old May 14, 2009 | 11:11 AM
  #481
str8dum1's Avatar
str8dum1
its based on whether or not your EMS can handle them. only the Haltech or the FCON can use low impedance peak and hold injectors.
Old May 14, 2009 | 01:31 PM
  #482
Mr_pharmD's Avatar
Mr_pharmD
good to know... but will I still need resistors if I go with low impedance injectors or will the VPRO be able to config the voltages?
So u going to buy Mike's old block??? I wish he had this for sale before my 2nd build
Old May 14, 2009 | 04:12 PM
  #483
str8dum1's Avatar
str8dum1
no resistors. those ECU's can support the load.
ya, going to pick up Mike's motor. It will prolly sit til i have everything for my next build. But it might be interesting to see how much hp i could get with my SC and a 200 shot behind it!
Old May 14, 2009 | 05:01 PM
  #484
Chef-J's Avatar
Chef-J
Booooosstt!!
Old May 14, 2009 | 08:32 PM
  #485
Mr_pharmD's Avatar
Mr_pharmD
lol... I say go out with a BAM but make sure to upload it on utube
Old May 17, 2009 | 07:25 PM
  #486
str8dum1's Avatar
str8dum1
on the built block obviously
Old May 22, 2009 | 11:27 AM
  #487
nothix's Avatar
nothix
cant the stock vortech filter be recharged like a K&N filter?
Were can I find replacement filters?
Thanks
Old May 22, 2009 | 11:36 AM
  #488
binder's Avatar
binder
The non-rev up new belt configuration requires a Gates 80 1/8" belt. It was posted many times that people use a 79.5" belt and the part number was even posted.
The 79.5" belt wouldn't even fit with my 3.12 pulley. it's a g35, i don't think that makes a difference but it was too short. I tried and 2 other mechanics tried to get it on there and no go. 80 1/8" works just fine for the 3.12 pulley though.
maybe the 79.5" is only needed for the 2.87 pulley then.
Old May 22, 2009 | 12:12 PM
  #489
nothix's Avatar
nothix
also, how often do yall clean the filter? Mine is filthy after only ~2k miles
Old May 22, 2009 | 12:26 PM
  #490
binder's Avatar
binder
if it's getting nasty i would say every oil change.
I can't speak from experience on vortech filters, but it looks like a gauze style filter media like k&n. I cleaned my CAI k&n about every oil change on my accord.
Old May 22, 2009 | 12:56 PM
  #491
nothix's Avatar
nothix
I'd like to try it before I leave for Zdayz on tuesday, but I'm afraid I mess it up and have no replacement.
Any clue where to order a replacement filter?
Old May 22, 2009 | 03:42 PM
  #492
Chef-J's Avatar
Chef-J
Booooosstt!!
I ordered longer than vortech filter(k&n) from autopartswarehouse but they canceled my order without telling me or ask. I have a part number at home. But u can put cai or k&n or filter on fi section, you will find a part number.
Edit: Part Number
Filter : RX-4140
Crank breath filter: 62-1020
Old May 22, 2009 | 03:51 PM
  #493
iStan's Avatar
iStan
ZR
http://www.knfilters.com/search/prod...x?Prod=RX-4140
4140 I believe
Old May 22, 2009 | 03:52 PM
  #494
Chef-J's Avatar
Chef-J
Booooosstt!!
I used 80 1/8 gate belt on my 3.12 with gtm setup, so I bought a 79.5 inch belt for my 2.87 setup...79.5 was short...I just used 80 1/8 belt with 2.87 (same size with 3.12)
Anyone know why belt breaks? I know if belt was too tight, it can cause break the belt. but other reason can cause break belt? After install 2.87 and old belt, it was tight as when I had 3.12. I never break the belt with 3.12...and I wasn't even drive hard after install 2.87 with this belt...
Old May 23, 2009 | 04:53 AM
  #495
binder's Avatar
binder
being tight is one good reason.
The other might be belt slip. Going to the 2.87 you might have some slip which would shorten it's life, but not enough slip to make it squeal. also look to see if somehting might be rubbing on it. That sucks the belt just broke.
About the filter, since it's the same material as k&n i would say a k&n filter recharge kit from an auto parts store should work just fine.
Old May 23, 2009 | 08:48 AM
  #496
jpc350's Avatar
jpc350
Default Belt dust
More than likely its the belt dust...I have found simply gently tapping the filter after removing it will shed a lot of the dust and return the filter for more use..Try it.
Old May 23, 2009 | 10:22 AM
  #497
Chef-J's Avatar
Chef-J
Booooosstt!!
Yea kinda scary, it broke on highway. I wasbt even pass 3k rpms
I'm going to put new belt tonight...hate to driving my dad's car...lol
Old May 23, 2009 | 10:54 AM
  #498
05Z33's Avatar
05Z33
When I bought my Vortech kit new it came with a 79.5 inch belt. Maybe Vortech made a change to the belt they supply now. Also my belt fit fine with the 3.12. When I upgraded to the 2.87 and GTM pulley mod I used the 79.5 belt and it was a perfect fit.
Old May 23, 2009 | 11:54 AM
  #499
Chef-J's Avatar
Chef-J
Booooosstt!!
So u mean u used same belt size with 3.12 and 2.87?
Old May 23, 2009 | 03:18 PM
  #500
binder's Avatar
binder
that's wild. wait, could the difference be that mine is a non-revup?
