Storing car
Old May 17, 2007 | 08:59 PM
redline350ZZ's Avatar
redline350ZZ
Default Storing car
Is it ok to store a Z with a Built motor for a couple months? I know everything electrical will be fine but I'm curious about the motor.
Old May 17, 2007 | 09:01 PM
wildmangk's Avatar
wildmangk
NOOOOOOOOOOOO, it's going to catch fire!!
Old May 17, 2007 | 09:02 PM
IntenseFab's Avatar
IntenseFab
Intense Motorsports
Yes it should be fine, if you can start it and let it warm up every few weeks or so that would be ideal. If you're going to store it for a long period of time avoid storing it with an excessive amount of fuel so it doesent have a chance to go bad .
An engine is an engine, built or not.
Old May 18, 2007 | 11:48 AM
synth19's Avatar
synth19
+1 on the fuel. Also, remove/disconnect the battery if possible.
Old May 18, 2007 | 02:55 PM
Zivman's Avatar
Zivman
Actually, I was under the impression that storing with a full tank of fuel was best. Having air in the tank causes the fuel to go bad.
Old May 18, 2007 | 05:14 PM
Cube's Avatar
Cube
Isn't there stuff you can pour into the gas tank to keep the gas from going bad?
Old May 18, 2007 | 05:39 PM
failsafe306's Avatar
failsafe306
Sta-bil <sp>
Old May 18, 2007 | 07:05 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
the pistons will spontaneously combust if not heat cycled at least once per month
just kidding, it'll be fine
Old May 18, 2007 | 09:29 PM
Cube's Avatar
Cube
Originally Posted by failsafe306
Sta-bil <sp>
Correct
Old May 18, 2007 | 10:41 PM
redline350ZZ
LoL, I'm just kinda bummed that I have not been able to run this motor yet and the car is apart while I get some plugs for the oil feed and return lines so that I can start the car again.
Old May 18, 2007 | 10:59 PM
Eazzy's Avatar
Eazzy
For a "couple" of months you have nothing to worry bout--fuel additive would be nice, full tank is best, disconnect the Battery---be good to trickle it
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
davidm350
Oct 31, 2015 02:28 PM
Mattg350z
Oct 2, 2015 06:51 AM
