weird ticking noise
Old May 21, 2007 | 06:00 PM
synth19's Avatar
synth19
Does it sound like "tick tock," "tick tock," "tick tock," "tick tock," "tick tock," "tick tock,"
Old May 21, 2007 | 06:47 PM
MADScientist's Avatar
MADScientist
no man... funny, but no!
Old May 22, 2007 | 04:52 PM
MADScientist
Well found out what the noise was guys... It was the lifters!
Did a leak down test and all cyl are within 3% of each other with 1bar of cyl psi as a base line. So the motor is still tight and no bent valves! Horray!
I am still trying to figure out how it happened, but the valve lash is way out of spec from what I originally set it at. For example, in cyl #3 the exhaust valve clearance was originaly set to .013" and now it is .024". Now there are only two way this could happen in my opinion. Either I am an idiot and measured wrong when setting to cold clearance, or something settled in these Cosworth heads.
Now I would be the first to admit if I made a mistake... But, a error of .011" is pretty huge! And the noise would have been there from the first time I started it. This noise came about 4000 miles after the build.
I have made a bunch of calls to see if anyone has an idea. Sharif has a call to Cosworth to see if something is going on with the heads from a machining process.
I will keep everyone posted.
Old May 22, 2007 | 07:12 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Joe, call me tomorrow...I have some more information for you.
Old May 23, 2007 | 11:24 AM
andypandy's Avatar
andypandy
damn. grats. at least it wasn't something heavily expensive such my ordeal. git'r running asap!
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
