609rwhp thanks to Sam @ GTMotorsports
Originally Posted by EM-EFER
The best I have saw so far was 20PSI @ 630whp from a shop in Deleware. Looked like after 20psi the 18'gs are out of steam.
Originally Posted by MR RIZK
The lower the timing the higher your EGT will be. Don't know what turbos u are running but u maybe out of the effeciency range of the turbo. Basically blowing hot air.
Originally Posted by Alberto
LOL try taking your own advice!! Enjoy your car man, I know being on the dragon with you was fun man...
I had a great time on the Dragon, gotta give you props... you and your Cali driving buddy got some mad carving skills..
Can't wait for the next time...
Trefling
Glad the car worked out as well as it did. It is an amazing powerband....definitely enjoy the heck out of it. Isn't it just a great feelign to have a car setup this perfectly.... Amazing.
good luck in the future. Sam IS THE MAN, simple as that.
Originally Posted by doug
look at the mods.. no cams.. no headwork... you can get way more out of that engine.. with less PSI
i havent seen enough examples of the twin pump kits on the street yet. i've heard of a couple of street cars, but mainly the shop cars are still r&d'ing them. someone can chime in if i'm mistaken. i'll be doing 750cc rc's and we will take them to the limit and then back off a little for street use. the only other option i've seen is going with a 1000cc injector and tuning with the fcon. i was really close to going with the AAM external pump but the noise was a little too much for me to bear in the G. hopefully i'll have the car back by the middle of june with break-in and tuning done by the first july.
Originally Posted by paranormal
btw i really dont believe anything over 550rwhp is really streetable..
then why were you contemplating getting the aps extreme kit? you already have the aps tt and a built motor. all you need if the fcon, and new fuel setup, and some tuning.
Originally Posted by trefling
Sam was telling me this it is comming to see as much as 14 or more degrees of advanced timing at WOT. He kept mine around 10 because we were not sure how well the engine was on the inside after all the sh*t my Z has been through not to mention the fact that my HKS knock/amp was not even installed even though I had paid for one
so we really didn't know what to expect and Sam didn't want to send me halfway across the US with a blown engine on a trailer...lolmore than 10 degrees of timing up top seems to be completely impossible...
what else do you have done to the car?
The FCON is a great engine management and has been known to be ble to extract the most amount of power out of a FI setup, but typically, to get over 600rwhp, on a stock greddy td0518g, you are going to need to run some pretty aggressive timing advnce if only pushing 14-15psi, aggressive as in; high octane fuel and 17/18 degrees advance up top.
Please reveal the secret.
-TODD
what fuel system should i go with? is Phunks stage 3 out yet?
yeah i think your right. im going to see what the kit i have on now is capable of.
Maybe he didnt tell to us his was stroke to 4.2L, and with 4.2L obviously is possible to made that power with 14psi and timing no more than 10 degrees
great numbers!, but I'm confused about the timing as well... to make 600+rwhp on 14-15psi, on stock greddy turbos, without running
I"m just going by what Sam told me while he was on the dyno. I do know for sure that the headwork and cams made a huge difference. But please ask Sam any further questions because i really don't know
