Vortech installation fuel pump vs OEM... fast question
Old May 27, 2007 | 03:59 AM
JCstart's Avatar
JCstart
Default Vortech installation fuel pump vs OEM... fast question
I'm actualy installing my vortech kit... and no where in the instructions they are refering to the OEM fuel pump...
they tell us how to connect the in line fuel pump but no where it is mentionned if we have to disconnect the OEM one ?
do I have to install the new one without removing or disconnect the OEM one ?
any help will be appreciated !
thank you !
Old May 27, 2007 | 04:38 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
they dont talk about the oem one cause they use two. they use the factory one in its normal usage and then add an inline one to help it and provide more fuel as necessary.
just follow the instructions as Vortech has them and you will be just fine...
Old May 27, 2007 | 04:51 AM
Eazzy's Avatar
Eazzy
In other words, the OEM feeds the Remote. I suggest you sit down and study the instructions avidly
Old May 27, 2007 | 05:22 AM
JCstart's Avatar
JCstart
I was thinking about that too...serial fuel pump... but now I'm more confortable to proceed...
thank you !
Old May 27, 2007 | 05:23 AM
JCstart's Avatar
JCstart
that is what I did and this is why I asked before do something...
thank you !
Old May 27, 2007 | 08:45 AM
THE TECH's Avatar
THE TECH
The instructions are quite clear.
Old May 27, 2007 | 05:13 PM
JCstart's Avatar
JCstart
yeah... clear as theirs photos....
Old Jun 1, 2007 | 08:56 AM
Triple8Sol's Avatar
Triple8Sol
Or you could just run a Walbro and not even mess with that inline pump, right?
Old Jun 1, 2007 | 12:28 PM
NS_350GT's Avatar
NS_350GT
^^+1
Dont waiste your time, or even trust that aux. pump.
Old Jun 3, 2007 | 12:34 PM
ForceInduction's Avatar
ForceInduction
No. The aux. pump works inline with the FMU. So you actually need it. Using a walbro instead of the aux pump will lead to big headaches if you just try to drop it in.
If you are going to switch to an intank walbro, it is better that you actually get larger injectors and a tune to control the fuel pressure, air/fuel ratio, and timing.
etkms
Jun 19, 2022 06:30 PM
Dr.Paulyy
Jul 29, 2019 07:45 AM
bcoffee20
Nov 19, 2015 06:39 PM
Mattg350z
Oct 2, 2015 06:51 AM
Calinismo350z
Sep 14, 2015 04:04 PM
