Which clutch to get for my TT setup?
Old Sep 28, 2007 | 10:50 PM
  #61
punish_her's Avatar
punish_her
Originally Posted by leeboyNY
Since I started this thread, I went with the Carbonetics twin carbon clutch with 1350kg PP. I was looking for a cheaper alternative, but it is clear to me now that single clutches that can hold 500+whp/trq are not daily drivable in a stop and go traffic...
Depends on your idea of streetable. My stage 5 Spec 6 puc clutch is streatable to me, I just have to relearn the engagement point and its characteristics. Yeah its a pain but I would not call it a full out drage clutch that you have to slip in order for it to heat up and work properly. To me thats not streetable.
Good choice though. Should be closer to what your looking for.
Old Sep 29, 2007 | 03:29 AM
  #62
vincent lam's Avatar
vincent lam
i'm using ORC409 single plate clutch for my PE TT,and i feel very little bit difficult to drive on street. any experience guys?
Old Sep 29, 2007 | 04:11 AM
  #63
XKR's Avatar
XKR
Good move You cant go wrong with Carbonetics Twin or Triple Clutch. I went with the triple and it is the perfect daily driver or perfect track system.
Old Sep 29, 2007 | 05:40 AM
  #64
leeboyNY's Avatar
leeboyNY
Kimchi Eater
We are talking about 500+ WHP clutches.. Your ORC 409 is streetable and well mannered, because it's not an extreme clutch that can handle 500+WHP.
My nismo+JWT single plate clutch is very streetable as well, but it won't hold 500+WHP...
Old Sep 29, 2007 | 07:16 AM
  #65
Spddracer's Avatar
Spddracer
The reason clutches get hard to drive is the presure plate design mainly,
When you change the pressure plate load and make it higher you also change how Quick or Violent the clutch behaves.
When you get to the point where the pressure plate is about maxed out to hold the power with a cheap clutch facing it gets Very Violent upon release which some people describe an ON-OFF type of clutch with little forgivness.
We use a moderate pressure plate load with a far superior clutch lining (feramic)
We let the superior clutch material with very good pressure plate design hold the power rather than just making the pressure plate as stiff as we can so the a cheap clutch facing material can hold the TQ.
Old Feb 5, 2008 | 07:27 AM
  #66
TTRANK's Avatar
TTRANK
Bump for updates
Anyone else try out the South Bend yet?
Old Feb 5, 2008 | 05:12 PM
  #67
Javierg35's Avatar
Javierg35
Default Anyone else try out the South Bend yet?[/
Originally Posted by TIMMAHH
Bump for updates
1+
Old Feb 8, 2008 | 04:45 PM
  #68
SpoilsofWar's Avatar
SpoilsofWar
Havent driven with it yet because my engine is at the machine shop, but heres pics of my South Bend DxD stage 5 clutch that arrived today:
Got it from Gin at Concept Z Performance.
Old Feb 8, 2008 | 04:52 PM
  #69
jksstar's Avatar
jksstar
you are going to like it, I have about 10,000 miles on mine and it still feels and holds the same as when I had it put in. I also drive on mine everyday and its not bad at all (wife has a hard time).
Old Feb 9, 2008 | 11:49 AM
  #70
TTRANK's Avatar
TTRANK
How much harder (~%) would you say it is over stock?
I'm trying to decide on one of these or an OS Giken twin plate and selling my UR flywheel.
Old Feb 13, 2008 | 12:31 PM
  #71
TTRANK's Avatar
TTRANK
Has anyone tried the SPEC twin plate clutches? They are very low price for a twin plate...
I tried to order an OS Giken but they are on backorder.
Old Feb 13, 2008 | 12:47 PM
  #72
thom000001's Avatar
thom000001
Cool,
Thats the clutch I went with too. It'll probably get here today but we haven't even started on my car yet. Still waiting on last few parts.....
T
Old Feb 13, 2008 | 12:49 PM
  #73
Javierg35's Avatar
Javierg35
How much is the SPEC TWIN PLATE $$$$$ ????? can you post the price ? if not send me a PM please
thanks!!!
Old Feb 13, 2008 | 12:51 PM
  #74
QuadCam's Avatar
QuadCam
I was looking at those twin plate spec clutches too. The only reason the carbonetics are so expensive is because they use the carbon clutch discs. a twin plate clutch with standard materials should be too expensive.....like the spec units.
Old Feb 13, 2008 | 01:28 PM
  #75
TTRANK's Avatar
TTRANK
The SPEC ones start ~$1200 and go to ~$1600 depending on plates you pick.
Andrew, I think that would be fine for my setup don't you? I would be very happy if I could get a clutch for ~$1400 that will still feel good on the street and last for a while.
Thoughts?
Old Feb 13, 2008 | 01:33 PM
  #76
TTRANK's Avatar
TTRANK
The SPEC ads I have found say it's carbon too.
Old Feb 13, 2008 | 02:27 PM
  #77
Javierg35's Avatar
Javierg35
Thoughts?
do you have a link ? just to take a look , I`m also looking for a clutch tha can hold 550whp and can be used for DD , and thats price range ( 1200 -1600 ) is really good compare to the EXEDY TWIN OR THE ATS TRIPLE
Old Feb 15, 2008 | 09:06 AM
  #78
TTRANK's Avatar
TTRANK
I just ordered one from SPEC this morning.
http://www.specclutch.com/
I got their super twin SS trim because after talking with them it should be more than enough for my situation and very nice on the street. They even gave me a nice discount!
It should be on the car early next month. I will post up a review then.
Old Feb 16, 2008 | 05:02 AM
  #79
QuadCam's Avatar
QuadCam
Tim,
I emailed them earlier in the week, and they recommended the SS35PT. Is that the one you ordered?
Here's a pic they sent me. This is not the G/Z clutch, but it is very similar, I was told.
Old Feb 17, 2008 | 01:04 PM
  #80
TTRANK's Avatar
TTRANK
Yeah that is the one I ordered. But now I just found a great deal on another one so I'm trying to cancel this order. I got it for well under retail from them because they wanted pictures of my car. If I can't cancel it do you want it Andrew? I'll have to make sure but I think it was ~$1080.
