"that sh*t is G"
Old May 28, 2007 | 07:46 PM
ke0ki2k's Avatar
ke0ki2k
Default "that sh*t is G"
that was the line i got from some guy at the light, then he asked me if it was turbo'd and i had to say "no". pretty sure im gonna start saving up, how much would it cost to have some low compression forged pistons, sleeves, head gaskets and studs put in? labor wise, i know the cost of all that stuff. cant find how much the labor is doh.
Old May 28, 2007 | 07:50 PM
michaeljr6's Avatar
michaeljr6
depends how much your local shop charges.
Old May 28, 2007 | 07:52 PM
Blk03G35's Avatar
Blk03G35
A lot
Old May 28, 2007 | 07:55 PM
ke0ki2k's Avatar
ke0ki2k
Originally Posted by Blk03G35
A lot
yeah i know, i might PM Sharif, i severely doubt theres a shop in Knoxville id trust with that kind of work.
Old May 28, 2007 | 09:12 PM
iceagetlc's Avatar
iceagetlc
G as in short for OG which is short for Original Gangster?
Or G as in G like G-money?
Or G, as in Jee, golly that's a nice car?
Or G as in Gay?
Old May 29, 2007 | 05:58 AM
NA&CH's Avatar
NA&CH
you have some of the weridest threads...
Old May 29, 2007 | 06:10 AM
SupermanZ's Avatar
SupermanZ
To have Sharif instal a vortech it was like $100 an hour for labor.
Old May 29, 2007 | 06:12 AM
Ghost 350z's Avatar
Ghost 350z
If you have to ask, you cant afford it
Old May 29, 2007 | 07:06 AM
NA&CH's Avatar
NA&CH
No offense Oyabun , but I hate that comment. Its almost like a rich person comment, ment for the Porsche, Ferrari, and Lambo guys... Not Z guys...
Chris
Old May 29, 2007 | 07:10 AM
Chako135's Avatar
Chako135
i agree, but there's almost truth behind it
Old May 29, 2007 | 07:20 AM
Ghost 350z's Avatar
Ghost 350z
Chris
None taken Truth is I wont ask the question and I cant afford it The fact is that the answer to the OP's is all over the FI forum.
Old May 29, 2007 | 07:47 AM
Cube's Avatar
Cube
Originally Posted by BuiltZMotors.com
This motor will be more than capable of 550 wheel horsepower, basically, the weak link will be the stock block (unsleeved)..we have a sleeving option as well for more power w/ pauter rods!
Pistons - Arias Extreme Duty 9:1 CR (estimated power rating above 1300-1500rwhp!)
Rods- Eagle Rods
ARP hardware- Main and head studs included (not sold extra like some other companies)
overhaul gaskets- every gasket new from Nissan
Headgaskets: stock (can upgrade)
rear main seals
main bearings
rod bearings
thrust washers
machine block (with use of torque plates)
balancing
polish crank
redeck heads and block- to ensure mating surfaces between the block and the heads are exact
clean parts- prep before assembly- clean oil channels, outer surface, etc.
oil pump- new from Nissan- recommended on a new motor build
Cams- stock (can upgrade)
Valves- stock (can upgrade)
3 angle valve job (3 on the valve seats, 2 on the valves)
Springs- stock (can upgrade for a higher revving application)
motor assembly – timed, with front and rear timing cover installed
head assembly- rebuilt with new valve stem seals
I think it'll run you about $6500 after sending your block back to them for a core refund. Then you got about $1400 for the swap.
How many miles on your block???
Old May 29, 2007 | 07:48 AM
NA&CH's Avatar
NA&CH
O yea there is truth behind the statement. Esp. when your 22 with a mortgage
Old May 29, 2007 | 07:49 AM
SirSpeedyZ's Avatar
SirSpeedyZ
Or G as in Gay?
Old May 29, 2007 | 08:04 AM
teh215's Avatar
teh215
He's provides free shipping of your car and, I believe, complimentary air fare to pick it up when you have them do a complete build up..
Old May 29, 2007 | 10:50 AM
myG35zx's Avatar
myG35zx
Actually I think it's funny. Many people that say it choose to live paycheck to paycheck. I can afford a lot. I choose to spend my money in different areas. There's difference between not affording and choice.
Chris
