???procharger???
Old Jun 5, 2007 | 07:35 PM
jasonM's Avatar
jasonM
Default ???procharger???
need to know how much boost can the prochargers ic can handle?
im stuck at 11.5psi is it my ic or maybe piping!
only reaching 5500 rpm then boost fades
thanx in advance
Old Jun 5, 2007 | 07:55 PM
MIAPLAYA's Avatar
MIAPLAYA
Are you sure the belt isn't slipping?
Old Jun 5, 2007 | 09:04 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
belt is not slipping, we tried to mess with it on the dyno and it seems like a boost leak or the intercooler being to small.
still made over 400 but it maxed out at 11 psi at 5500, that car could be nasty if it made full boost to redline!!
Old Jun 5, 2007 | 09:05 PM
MIAPLAYA's Avatar
MIAPLAYA
Interesting. I guess its possible the intercooler has reached max flow but it seems large enough to support more. Of course who knows what kind of core that is.
Old Jun 5, 2007 | 09:17 PM
Audible Mayhem
My350z
well i didnt think the IC was maxed out but my boy jason said he heard someone say that so it was brought up. i think he was checking out the kit for boost leaks....
Old Jun 6, 2007 | 04:46 AM
delaharsha's Avatar
delaharsha
check the valve!!!
Old Jun 6, 2007 | 04:57 AM
booger's Avatar
booger
You might have a boost leak at the plenum . And you cant tell its there until you're in the upper boost levels . It happened to me . Cap off the exhaust and make a capped off pipe with a quick connect air fitting on the end of it . Disconnect the IC pipe right after the blower and hook up the pipe there . Hook up the air compressor set at 40 or 50 psi . Then listen for leaks . Works great .
Old Jun 6, 2007 | 11:06 AM
ForceInduction's Avatar
ForceInduction
It the boost is dropping two things come to my mind. The by-pass is not holding up at high boost levels or your reaching the efficency of the blower.
Old Jun 6, 2007 | 11:13 AM
chris'smax's Avatar
chris'smax
do a smoke test on that sucker. If the vaccum checks out and the belt isn't slipping then i would look to the intercooler.
Old Jun 6, 2007 | 02:10 PM
350Z_LEE's Avatar
350Z_LEE
The c-2 procharger can support a lot of power, and I don't think it is the intercooler either. Check the weaksauce ati provided bypass valve. I would upgrade to a bov for sure. If that doesn't fix it, try running it with the air filter off and see what that does. I remember a buddy of mine having an issue with the filter.
350Z_LEE's Avatar
350Z_LEE
My power is all in at 6k though.
Old Jun 6, 2007 | 02:25 PM
Audible Mayhem
My350z
we were on a time frame and a budget on this. he has a Greddy RS bov on the car. i really feel like there is a simple boost leak with the car. i told him that i would get rid of the spacer cause it probably isnt helping the power levels and might be the cause of the leaks...
he was going to check all the piping and the plenum spacer
Old Jun 6, 2007 | 03:47 PM
booger's Avatar
booger
I had to triple up the gasket on the plenum to fix mine . The Crawford plenum warps a little when they weld it back together .
Old Jun 6, 2007 | 06:43 PM
jasonM's Avatar
jasonM
i removed the spacer but cars still only making 11psi as soon as i get a chance im going to pull the bumper and check all the clamps
Old Jun 6, 2007 | 07:19 PM
Audible Mayhem
My350z
yeah man, that one hose/piping that was against the bumper reinforcement might be the issue, you should get a cheap U bend and bypass the IC too. that would be interesting to see
let me know man, as soon as you get it resolved, i will throw it back on my dyno and get that graph to keep pulling to redline, that would be nasty !!!
Old Jun 14, 2007 | 05:15 PM
05nissan350z's Avatar
05nissan350z
get a new motor i have 9psi with 500hp
NissanZcrazy
Sep 23, 2015 07:59 AM
jesseenglish
Mar 7, 2004 02:23 PM
Dr Bonz
Sep 20, 2003 09:14 AM
TXSTYLE
Aug 7, 2003 10:30 AM
JoeAE2005
Jul 10, 2003 06:59 AM
