My set up...
Old Jun 6, 2007 | 09:45 AM
doug's Avatar
doug
Originally Posted by Lawy'dU
doesn't the greddy turbo kit come with two 20G turbo's from the evo? I do beleive so.....
Get a bigger exhaust. The HKS which is a wonderful system is only 60mm wide. Go for the AAM dual 3", upgraded heads, SSV, fuel system upgrade, etc. and get a good tune since you have pretty much everything you need at this point.
Greddy Kit comes with two 18G turbos i believe and he already has most of those mods you described
Old Jun 6, 2007 | 09:51 AM
TENGAI's Avatar
TENGAI
Different animals all together. Supras are highway kings, and not typically known for being off-the-line monsters. Yes, there have been plenty of sub 10sec Supras out there, but where they really shine is on the loooooong straits from a nice 80mph roll.
In any case, 600+whp is nasty fast in any car. Setting big goals for monster whp levels is something you should carefully think about if you ever intend on driving the car on the streets.
Old Jun 6, 2007 | 10:01 AM
Zridder19's Avatar
Zridder19
An 800hp Z is crazy! From personal experience, Just riding in AJ's car, and Jet's car back in the day was rediculous. I believe they were both making about 450hp or so and no traction. But good luck to ya.
If you end up doing it, might want to purchase one of these.
Old Jun 6, 2007 | 10:31 AM
Lawy'dU's Avatar
Lawy'dU
ahhhhh....about the turbo's, and no for the rest (it looks like).
Old Jun 6, 2007 | 10:43 AM
incubi2033's Avatar
incubi2033
Default dyno
dyno
Old Jun 6, 2007 | 10:57 AM
doug's Avatar
doug
He already has an HKS Exhaust..
on a side note.. that dyno looks like a ST dyno
Old Jun 6, 2007 | 11:36 AM
Jason333's Avatar
Jason333
hi
450 seems low for your setup. I would assume much closer to 500 esp on a dynojet
Old Jun 6, 2007 | 11:54 AM
Cannysage's Avatar
Cannysage
Originally Posted by incubi2033
GT Motorsports Built Bottom end with Sleeves 8.5:1 comp. stock stroke and bore 3.5l
Stock Heads... didnt have the budget at the time
1000cc injectors
PTP Fuel System
Greddy Twin Turbo Kit
HKS Hi-Power Exhaust
HKS F-Con
running 15psi made 450rwhp
My shop suggested the Extreme APS kit and Cosworth or GT Motorsports Heads. I just want to get some opinions from some other people who might have experience with certain products.
Thanks for the help... let me know if you need any more info
you'll need to get rid of the hks and get a bigger exhaust system + JWT cams
Old Jun 6, 2007 | 11:55 AM
incubi2033's Avatar
incubi2033
at the time when it was tuned I only asked for 450whp so they stopped once they hit my goal. they said the car can make more horsepower as is but since I was happy no need to make anymore power at the time.
Old Jun 6, 2007 | 11:58 AM
incubi2033's Avatar
incubi2033
Originally Posted by westpak
also add a widebody kit and 12 inch rims if you want any hope of driving that thing on the street, get some realistic goals.
it has a veilside v. 3 widebody and 11 inch wheels on the back
Old Jun 6, 2007 | 02:38 PM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Old Jun 8, 2007 | 05:51 AM
rcdash's Avatar
rcdash
If I had the goal of 800 whp, here would be my plan of attack given where you are now with the car:
I think the best bang for the buck would be to change the exhaust. 2.25" even though true dual might not be flowing well enough. If you really like the HKS, then you can install electronic cut outs up top (pre-cat) and I'll bet you'll get a 50 whp jump right there.at 15 psi and the curve will look dramatically different.
The next best bang for the buck, which you'll need after your exhaust mod, which is why I mention it 2nd, is another tune. You said yourself that they stopped at your power goal. You don't know how much power your engine can make yet, but I bet with exhaust cut outs and an aggressive tune w/ the FCON you can get into the 600 whp range.
A small helpful next step might be to add water/meth injection considering you're in a hot location. You can be more aggressive with the tune if you've got some extra cooling going on, triggered automatically by your FCON.
Finally, to get you to 800 whp, the best bang for the buck (notice the theme!) IMO would be to add a nitrous shot (150 hp). And voila, you're there for less than $3k total added expense.
EDIT: good luck controlling that beast!
Old Jun 8, 2007 | 06:01 AM
Gman2004's Avatar
Gman2004
He posted up a dynojet dyno chart.
Old Jun 8, 2007 | 07:25 AM
chris'smax's Avatar
chris'smax
+1 on this guy's advice, except i would suggest the boost actuated cutout offered by atpturbo. I had these on my old car and they are cool as hell. The actuator can be controlled by a boost controller.
