What can you do on stock heads, cams, greddy twins and a short block?
Congrats! This is with the Torco C18 fuel?
And it smells really nice too.
What kinda testpipes are you running? Are you using the stock greddy downpipes?
We need a intake plenum fast, that power drop at the end is crazy.
Originally Posted by Sharif@Forged
Calling now...I heard you fixed your issue.
Turbo XS test pipes and standard Greddy downpipes. This car is the ultimate sleeper.
Originally Posted by accordfreak
What was the total price of that simple build? I want to go the same route with ONLY the pistons and the rods changed out with a fresh bore.
Man those numbers are horrible for a built bottem end with no head work, You sux J.....
J/K
Man you know that car is one clean ride, nice to see you again also. Take it easy with the HP.
J/K
J/K
J/K
The "simple" buildup was about $10K, but like many projects, the customer decides that they want to add more goodies as the project progresses. We also found quite a few defective/broken pieces from the previous stock block buildup, that needed replacing as well. We discovered one of the worst attempts at a return fuel system I have ever seen.
yeah, i guess i could have mentioned all the "oh! i want!"s... but, the bulk came from replacing all of the crap that was on the car... and you didn't like the return fuel system?? i made that special out of McDonald's straws JB Weld'ed together...
what did it consist of?
Stormcrow's car smelled like the inside of a fuel tanker.
One flick of a bic, and the car was likely to explode!
