coolant racing
Old Jun 24, 2007 | 08:09 AM
Phanatic's Avatar
Phanatic
Originally Posted by Sharif@Forged
We are trying Evans NPG+ this weekend, at Barber, so I will report with any changes to coolant temps. If I push it hard enough, I can get the temps to start creeping up after about 5 hot laps. We'll see if the NPG+ waterless coolant helps.
How did that coolant do?
Old Jun 25, 2007 | 07:57 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
It definately kept my coolant from boiling and causing an issue. However, my sleeved block is giving me some heat retention issues, that I will have to live with until I do another shortblock. IMHO, sleeving is not the way to go for a road racing car. No signs of headlift or anything, but it ran pretty darn hot!
Old Jun 25, 2007 | 08:09 AM
nismology1's Avatar
nismology1
Using NPG+ will give the impression that the engine is running hotter than usual when the temps are perfectly acceptable. From what I've read, it reads hotter than before on gauges because it's effective at removing MORE heat from the motor due to how it can sustain the nucleate boiling @ hotspots around the combustion chamber. This is where measuring block temps > coolant temps.
Did you consider the NPG-R coolant?
Old Jun 25, 2007 | 08:50 AM
Sharif@Forged
Forged Performance
Evan's recommends the R only for race cars that are not daily driven, so I havent tried it yet. Have you tried it before?
The great thing about Evan's is the 375F boiling point. With regular coolant, as you approach 220-230F, that coolant starts to foam slightly, and this inhibits heat transfer.
This is our first time using Evan's on the track, so I am sure we'll have more experience with it over the next few months. We have a lot of track events on the schedule that we'll be attending.
Old Jun 25, 2007 | 11:21 AM
Phanatic's Avatar
Phanatic
sweet, thanks for posting thoughts/feedback
Old Jun 30, 2007 | 05:10 PM
Mike Wazowski's Avatar
Mike Wazowski
Should I use the Prep-Fluid before filling up with the NPG+ ?
Old Jun 30, 2007 | 05:12 PM
Sharif@Forged
Forged Performance
Not a bad idea, but its really only needed on engines where you cannot access the block drain plugs, or if you have difficulty purging the heater core. For the DIYS job, it would certainly help, since it can be difficult to get all of the water out of the system.
Old Jun 30, 2007 | 08:19 PM
rcdash's Avatar
rcdash
Sharif,
What do you refill your customer's turbo'd cars with when installing?
Would you recommend Evans for all turbo cars? We're not upgrading the radiator in mine, so just wondering if this is a good stop gap measure...
Recommendation appreciated - thanks.
Old Jul 1, 2007 | 08:39 AM
Sharif@Forged
Forged Performance
Originally Posted by rcdash
Sharif,
If you plan on tracking the car at a road course, then I think we should. And now would be the time to do it, since your engine is already devoid of water. BTW, I see your email in my inbox, but just havent got to it. I wil respond on Monday. THANKS!
Old Jul 1, 2007 | 09:15 AM
rcdash's Avatar
rcdash
No worries - I'm sure you'll be as glad as I am when I've got my car back - your e-mail load will be cut in half.
Let's try the Evans (NPG+). I see no disadvantage (other than cost)...
Hope you get a few days R&R for July 4th.
Old Jul 1, 2007 | 09:56 AM
Q45tech's Avatar
Q45tech
The problem is one of small coolant VOLUME...............developing methods to increase it a few quarts will work wonders............larger radiator, inline sump tanks.
Really hard to improve radiator efficiency by more than a few %.
Old Jul 1, 2007 | 10:48 AM
rcdash's Avatar
rcdash
Volume is one of the factors, yes, and it's a good thought. Using non-aqueous propylene glycol has more to do with the heat transfer properties of the coolant than radiator efficiency per se. Evans coolant will absorb more heat off the engine than regular coolant. While radiator efficiency doesn't really change the increased ability for Evans coolant to absorb and release thermal energy along with the increased temperature differential between the coolant and air (as the Evans fluid will run much hotter) allows for greater heat dissipation utilizing the same (stock) radiator.
EDIT: Found the specs for the specific heat of NPG+ is 0.64 (compared to 1 for water and .81 for a 50/50 coolant mix). As you can see the NPG is going to pull nearly twice the amount of heat from the engine vs. water. And as Sharif mentioned, it will not form a vapor phase until over 370 degrees, even at 0 psi.
Old Jul 1, 2007 | 02:15 PM
nismology1's Avatar
nismology1
The #1 advantage of Evans over conventional coolants is how it sustains nucleate boiling (which absorbs a ton of heat). People that think Evans eliminates boiling completely are mistaken. The phase change that occurs when coolant starts to boil at hotspots in the block/heads absorbs a considerable amount of heat. The trick is to keep a vapor layer from forming at the site of localized boiling and keeping the liquid in contact with the metal. Evans does this by immediately condensing back into liquid form.
Old Jul 1, 2007 | 02:22 PM
nismology1's Avatar
nismology1
NPG-R will work just fine in daily driven vehicles. It's just not classified as a "lifetime coolant" yet to due insufficient long-term testing by Evans. They recommend replacement every other year for street/strip cars and every year for cars that see extreme racing duty like road racing. They don't recommend it in super cold climates either. As someone that lives in south florida I could run R year-round. But for people up north, NPG+ is the ticket if you don't feel like switching back and forth. From what I've read on their site, R has better heat transfer properties and is less viscous than NPG+. I haven't personally used it yet, but it will be going into my built all-motor engine when I get around to it.
Old Jul 1, 2007 | 03:00 PM
Abishop's Avatar
Abishop
What are some good ways to keep your over flow tank from boiling over?
Old Jul 1, 2007 | 03:43 PM
Sharif@Forged
Forged Performance
As long as the reason for the spill over is not head lift, then just use a larger overflow tank. Evans really helps keep my coolant overalll from going nuts. Also, make sure there is just a splash of coolant in the overflow before you start tracking, which will give it plenty of room for expansion. An upgraded rad cap will help as well.
If you are running that tiny APS overflow, get a new one...that thing holds virtually nothing.
Old Jul 1, 2007 | 03:44 PM
Sharif@Forged
Forged Performance
Good info. I just spent $100 on 3 gallons fo NGP+ so not too sure when I'll be switching, but we'll certainly give it a try.
Old Jul 1, 2007 | 03:50 PM
  #38
meatbag's Avatar
meatbag
+1 I'll be using it eventually
I know a couple people that run NPG-R in high hp cars(Ford Lightning, couple supras, rx7, '79 280z) that are almost driven daily and they tend to flush it every other year just to be safe. Being in Houston we dont have to worry about freezing that much.
Old Jul 1, 2007 | 04:39 PM
  #39
rcdash's Avatar
rcdash
I couldn't find this NPG-R on their website, but this page has lots of good info on NPG and NPG+: http://www.evanscooling.com/html/tech1.htm
Old Jul 1, 2007 | 05:04 PM
  #40
nismology1's Avatar
nismology1
http://www.evanscooling.com/main25.htm > Catalog > EVANS WATERLESS NPG+™ COOLANTS > NPG-R
Click on the "NPG-R" hyperlink for a more detailed description when you get to that last page.
