Possible Fuel Leak
Old Jun 15, 2007 | 07:11 AM
synth19's Avatar
synth19
Pardon the ignorance since I have not taken out the fuel pump or did my installation, but is the o-ring in quetion #194 in the following diagram? Thanks
http://www.chicagoZ.com/fuel.pdf
Old Jun 15, 2007 | 08:03 AM
minus500's Avatar
minus500
I'm almost positive it's not. There should be an o-ring about 4-5" in diameter that sits between the top of the tank and the pump assembly that seals the assembly and the tank. If its worn, then fuel will slush over and out.
Old Jun 15, 2007 | 08:27 AM
Zivman's Avatar
Zivman
The O-ring you want actually sits on top of the fuel tank in a grove and the assembly seals down on top of it.
$22 is WAY too much for that. you need to have an 'in' at the dealership and get deals on OEM parts. I think I pay 7-8 bucks for these O-rings; Heck I keep one on hand just in case.
Talk to Irshad, I bet he may have one on hand, or at least get you one for cheaper than $22.
Old Jun 15, 2007 | 02:19 PM
minus500's Avatar
minus500
I went to the Nissan dealership and got it for $10.73. Hope it helps.
Old Jul 14, 2007 | 03:54 AM
Barzten1's Avatar
Barzten1
Theres got to be a better way to seal the fuel assembly off. Just replaced my O-ring because I was getting the fuel smell and now it seems worse. The smell is so bad. Im wondering if its the return fuel tap into the assembly?
derekinthez
South East
Sep 28, 2015 06:35 PM
