check OUT these NICE pics!!!!
Old Jun 21, 2007 | 03:49 PM
jasonM's Avatar
jasonM
Default check OUT these NICE pics!!!!
all new pics page 2
clank dank clank rank!!???????
not again!!!!!!!!!!!!
broken crank
their not that nice i guess
http://pictures.aol.com/ap/singleIma...v4xQp5Fd3Ig%3D
Old Jun 21, 2007 | 03:52 PM
350Z84's Avatar
350Z84
Well I'm no mechanical expert, but that doesn't look good.
Old Jun 21, 2007 | 03:53 PM
jasonM's Avatar
jasonM
i think my crank might be broken
i now its broken the crack goes all the way threw
Old Jun 21, 2007 | 03:54 PM
Weqster's Avatar
Weqster
wow.
Now that i havent seen before.
*claps*
Old Jun 21, 2007 | 03:55 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
how did you manage that?
Old Jun 21, 2007 | 03:56 PM
350Z84's Avatar
350Z84
Yeah, so what happened exactly?
Old Jun 21, 2007 | 03:57 PM
jasonM's Avatar
jasonM
not really sure car just killed and would still turn over but sounded horrible so i pulled the motor and oil pan thats what i found
the motor was already blown once with a bent rod and had been rebuilt with eagle rods and wiseco pistons
Old Jun 21, 2007 | 04:00 PM
jasonM's Avatar
jasonM
i did just have the boost raised to 14 psi with the procharger but do to a boost leak i was only boosting around 11psi at 5400 rpms so
i was not reving over 5400 so i was nt even pushing it
Old Jun 21, 2007 | 04:02 PM
jasonM's Avatar
jasonM
has any one else broke the crank before??
Old Jun 21, 2007 | 04:03 PM
fallenromeo's Avatar
fallenromeo
ouch.
Old Jun 21, 2007 | 04:05 PM
taurran's Avatar
taurran
They're often rendered unusable when a motor blows. I'm not sure of the usual extremity of the damage. How long did you run the built motor before this happened?
Old Jun 21, 2007 | 04:07 PM
jasonM's Avatar
jasonM
9 or 10 months on a very safe tune only 330whp on 9psi
Old Jun 21, 2007 | 04:11 PM
doug's Avatar
doug
oh man.. Dan Marino lost 22 pounds
Old Jun 21, 2007 | 04:44 PM
jasonM's Avatar
jasonM
im gettin an rsx
Old Jun 21, 2007 | 05:03 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Seems like your previous engine blow did a number on that crank.. Then 14psi put a finishing touch...
Old Jun 21, 2007 | 05:06 PM
QuadCam's Avatar
QuadCam
i wonder if the crank was damaged in the previuos blown motor? or maybe the machine shop didn't properly balance the rotating assembly and it caused some odd harmonics that caused the crank to fracture........
speaking of harmonics, what kind of crank pulley do you have?
skidmarq's Avatar
skidmarq
Doggonit, I guess my original guess was way off. I thought that was a new custom oil flow modification...
Old Jun 21, 2007 | 05:45 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
hey jason, as i told you on the phone, i have never seen one of these cranks break like that. we even had one that we banged on the curb, threw off the building, and banged on the street trying to break it, it wouldnt even begin to break.
i would definitely contact the place you got it built, i forget, did they reuse any of your stuff or did they use all stuff that they had....
thanks man, talk to you in a bit
Old Jun 21, 2007 | 05:53 PM
Jokestrap's Avatar
Jokestrap
I broke my crank in half two months ago. The main crank pulley broke completely off while running hard and sent everything spinning everywhere inside my built motor.
Old Jun 21, 2007 | 06:23 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
easy fix. Weld it back together.
that blows
