psa: zdayz red g35 vortech owner, your jackshaft pulley is installed wrong
Old Jun 26, 2007 | 05:12 PM
98intrigue's Avatar
98intrigue
Originally Posted by CUxtopher
towards the rear of the car.
from the intall ins, 6.I;
"...install the aluminum idler with the bearing retainer snap ring pointed towards the rear of the vehicle."
Learning the instructions from front to back? Haha
Old Jun 26, 2007 | 05:16 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
yep, ill be doing a self install so i gotta know what im in for!
Old Jun 26, 2007 | 05:48 PM
Gilley's Avatar
Gilley
Thanks again, sir!! I had it right.
Old Jun 26, 2007 | 06:05 PM
stormcrow's Avatar
stormcrow
Originally Posted by Sharif@Forged
And for the record, it wasnt installed by us, but I guess we should have caught it.
But seriously, thanks for bringing this up...it is easy to see that this could easily be confused.
oh, don't even pretend... you know you did it! and you installed my vortech where it was sucking instead of blowing! i hit -30 vacuum at WOT and put down 40rwhp on the "heartbreaker"!
Old Jun 26, 2007 | 07:49 PM
zzerotwosixty's Avatar
zzerotwosixty
LMAO!
Old Jun 29, 2007 | 07:32 PM
DMK's Avatar
DMK
For tightening the cog belt wouldn't it be opposite logic. Because the belt stretches at it gets hotter, would it not get more loose? So making it tight when cold makes sense, similar to the serp belts where you pmly want a little bit of play. Or am I totally wrong?
Old Jun 29, 2007 | 08:14 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
The OP needs to be sent some complimentary beer!
Old Jun 30, 2007 | 04:45 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
+1 , id drink to that
Old Jul 2, 2007 | 11:38 AM
jpc350z's Avatar
jpc350z
My serp belt gets tighter when hot..(Gates) The Cogger also gets tighter as evidenced by gretaer tq. to turn the idler when hot...
Old Jul 13, 2007 | 02:33 AM
DMK's Avatar
DMK
How far down the adjustment slot are your guys' tensioner bolt set? Mine was all the way down, but since some people are saying that too tight when cold is bad, I adjusted it to only 3/4 the way down. I can twist the cog belt almost 90 degrees at the bottom now. Good or bad?
Old Aug 22, 2007 | 12:34 PM
eez's Avatar
eez
freekin crappy vortech instructions. for the non rev-up (section 5) it tells you exactly how to mount the idler. For the rev-up it just says to refer to pictures 6-e and 6-f (which there is no 6-e). So I have mine on WRONG. I just guessed when I installed, now looking back at the non rev-up instructions + this post I need to go back and change mine
Old Aug 23, 2007 | 04:03 AM
Chucky's Avatar
Chucky
That's what we are all here for... informational posts.
Old Aug 23, 2007 | 04:34 AM
stormcrow's Avatar
stormcrow
lies. you are here for the buttsechs.
Old Aug 23, 2007 | 04:36 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
the instructions actually say the right way but then i believe there is a picture that shows it in backwards...
kyin
Oct 15, 2015 05:54 AM
seagrasser
Oct 11, 2015 03:27 PM
codek
Sep 28, 2015 03:03 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
