HELP ! Vortech inline fuel pump do not kick in any more !!!!!
Old Jun 27, 2007 | 01:22 PM
JCstart's Avatar
JCstart
Unhappy HELP ! Vortech inline fuel pump do not kick in any more !!!!!
Hi there !
I need some help here...
I went to my tuning shop to get tuned
We did the first run, it was piggy rich !
we upload in SS box a new fuel mapping with only one cell correction... we did a new dyno and it was so lean !
we did 5 dyno run, with differents fuel mapping... and absolutely no change...still dangerous lean....!!!!!
after few hours of thinking... we found that after the first upload... the fuel pump did not kick in anymore...
any one know what happening here with the SSbox because it control the pump?
May I have to change some settings in R4 software menus ?
Old Jun 27, 2007 | 05:57 PM
booger's Avatar
booger
Was it ok after we talked and got your settings straight ? Let me know will you .
Old Jun 27, 2007 | 06:15 PM
THE TECH's Avatar
THE TECH
Yeah, answered your PM, let us know how it is going.
Old Jun 27, 2007 | 06:38 PM
booger's Avatar
booger
We had talked on the phone and I walked him thru changing back the settings in the R4 . Sounded like he got them changed right .
Old Jun 27, 2007 | 06:39 PM
THE TECH's Avatar
THE TECH
So some settings for the pump got changed by his tuner or himself?
Old Jun 27, 2007 | 07:09 PM
Triple8Sol's Avatar
Triple8Sol
Are you sure you have all the settings right in the R4 program? Go to Options --> Output Settings and see what the Fuel Pump settings look like.
Old Jun 27, 2007 | 07:20 PM
booger's Avatar
booger
What happens when you first up load the maps for the first time, is the setting change . And before you write the changes to fuel and timing ,, you have to make sure all the sesttings for the fuel pump to come on are correct . It happened to me three years ago when I first went to tune my car . If you dont know about it before hand you can be stumped trying to figure out why it went lean on you and why the pump doesnt come on
Old Jun 27, 2007 | 11:27 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
If the settings are ok then check the 12+ lead that feeds the auxillary pump from the SS box. I seen the SS box fail on the (of all the cars it could happen too) the first Vortech/Sony supercharged 350Z.The 12+ to the auxillary pump went kapoot when I was tuning the car.I ended up hardwiring the pump to the battery for the dyno session till the SS was replaced.Good luck
Old Jun 28, 2007 | 03:18 AM
JCstart's Avatar
JCstart
Smile
Thanks for your help!
After I talk to Booger and update the output setting in the options menu. The pump start to kick again. What happen:
After the first read from the ssbox I didn't change the output settings because I was thinking that are ok and come from the ssbox. Error...
I change the Over pressure and rpm with recommandations of Booger.
After, I write to the ssbox with new settings and I keep my this in my R4 file.
Check pump with test light, I was ok!
Now I'm ready to go back on the dyno to tune my fuel curve because it
was piggy rich....
Thank again Boog!
Attached Thumbnails HELP ! Vortech inline fuel pump do not kick in any more !!!!!-r4soft-output.gif
Old Jun 28, 2007 | 06:29 AM
THE TECH's Avatar
THE TECH
Glad it was a simple fix!
Old Jun 29, 2007 | 03:36 PM
Triple8Sol's Avatar
Triple8Sol
What...no props to me in post #6? Geez! lol...
kyin
Oct 15, 2015 05:54 AM
