TN with cams and stock engine?
Old Jun 27, 2007 | 04:02 PM
failsafe306's Avatar
failsafe306
Question TN with cams and stock engine?
Does anybody have any dyno graphs of a stock TN kit on stock block with aftermarket cams? Just curious as to what the cams would do to the normal power curve...
Thanks
Old Jun 27, 2007 | 04:07 PM
taurran's Avatar
taurran
I don't think so. I'd assume it would move peak power later but I'm not sure of the degree to which the top end would be effected.
Old Jun 27, 2007 | 04:27 PM
failsafe306
I searched and only found one thread asking the same question, with one reply lol. And the reply didn't help.
Old Jun 27, 2007 | 04:58 PM
taurran's Avatar
taurran
You could be the first. Then we all could reply with certainty.
Old Jun 27, 2007 | 05:00 PM
failsafe306
Yes! I'm the first at something!
FrickU's Avatar
FrickU
Depends on the cams, but more high end power, where all the rest of the TN kits power is.
Old Jun 27, 2007 | 05:10 PM
taurran's Avatar
taurran
Actually this kit is known for having great midrange power and torque, but tapering off on the top end. I'm not sure how much cams would help due to some of the hot side piping restrictions. I'm sure it would help to a degree, but we don't know until we try right?
Oh, and my car will be running JWT C2's but will also be built with some custom piping. We'll see how they work out.
Old Jun 27, 2007 | 05:12 PM
FrickU's Avatar
FrickU
I've driven about 3 of them on the stock motor, and nothing seems to happen until 4k. Kind of like my evo, but there should be a way to get the for more low and mid range power. When I installed cams on my evo they helped my spool a lot in the low and helped all the way across the powerband.
Old Jun 27, 2007 | 05:13 PM
failsafe306
I'd imagine running an open wastegate dump would improve that some, right?
Old Jun 27, 2007 | 05:15 PM
taurran's Avatar
taurran
You must have had some leaks somewhere because all of the properly installed (non-exhaust-leaking) turbonetics Z's and G's I have seen have hit a full 8-9psi around 3200-3500rpms.
failsafe306
That's what I'm hoping for.
Old Jun 27, 2007 | 05:16 PM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
I think he was referring to the downpipe. It's definitely lacking. But other than that and some other minor things, I never had a problem with the kit. You are going to love it.
taurran's Avatar
taurran
Yes, to a point... We looked even before that on the up pipe that comes with the kit. I think there's a lot of top end power to be made there.
Actually I believe the downpipe is the lesser of piping issues.
Old Jun 27, 2007 | 05:18 PM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
You would definitely know the kit better than me haha.
Old Jun 27, 2007 | 09:45 PM
MIAPLAYA's Avatar
MIAPLAYA
Yes I have to be honest I have yet to see a Turbonetics kit running a set of cams on a stock motor. Should be VERY interesting...
Fixxxercask
Nov 9, 2015 11:10 AM
