New Tune On Vortech
Old Jul 2, 2007 | 06:36 PM
  #41
doug's Avatar
doug
Originally Posted by zzerotwosixty
And the reason is... (drum roll) they don't know how to tune it. Once again. What can they do (aftermarket standalone) that the original ECU can't?
he just told you.. it controls boost..
but i hope both of you two gentlemen have long FI setups and make us eat our words
Old Jul 2, 2007 | 06:40 PM
  #42
zzerotwosixty's Avatar
zzerotwosixty
Originally Posted by doug
is this a joke? i hope this is a joke... you had a F Con and a UTEC.. but go rid of them so the ECU can control 18 PSI of boost?
you do realize that you can blow your motor with a Greddy Kit and 5.5 PSI of boost right? because the ECU gets wacky with the Timing and BOOOOOOOOOOOM
You mean pulling timing when it senses knock. That's there to keep it from going boom.
Old Jul 2, 2007 | 06:43 PM
  #43
zzerotwosixty
No it doesn't. The boost controller, or the WG, or the pulleys(SC) do.
Old Jul 2, 2007 | 06:46 PM
  #44
doug's Avatar
doug
all the best
Old Jul 2, 2007 | 06:49 PM
  #45
zzerotwosixty
Josh did your F Con have a boost controller on it? I don't mean attatched with tape.
Old Jul 2, 2007 | 06:55 PM
  #46
dovla's Avatar
dovla
Zzerotwosixty, will you add fuel return line?
Old Jul 2, 2007 | 07:03 PM
  #47
josh846's Avatar
josh846
zzero, not sure I had it, for like 2 weeks never installed it, decided to with with UPREV, the new stuff they having coming out, which I am guessing not many people know about. I have been using them for a while. They have done alot of work on and with my car. I bought it back when cipher came out.
Old Jul 2, 2007 | 07:06 PM
  #48
zzerotwosixty
No, I'm getting all the fuel I need. 11.0:1 from 3000 to 7100.
Old Jul 2, 2007 | 07:11 PM
  #49
zzerotwosixty
Josh, I was joking. It didn't have a boost controller on it. LOL
Old Jul 2, 2007 | 07:45 PM
  #50
dovla's Avatar
dovla
Perfect, I’ll need one item less - my vendor is not going to like this. LOL
I guess you already have oil cooler?
Old Jul 2, 2007 | 08:04 PM
  #51
abyss's Avatar
abyss
Originally Posted by josh846
they know more about the ecu than probably anyone else on here.
Old Jul 2, 2007 | 08:38 PM
  #52
zzerotwosixty
I've got an old Earl's laying around. It's been on several cars from Porsche to Pontiac. No kidding. I just don't feel the need for it. Easier just to change the oil at 2K miles. Oil pressure's good(shrugs).
Old Jul 2, 2007 | 10:46 PM
  #53
Nexx's Avatar
Nexx
Originally Posted by abyss
ahh, maybe techosquare knows more, but no one else comes close to knowing the stock ecu more then uprev.
Old Jul 3, 2007 | 08:42 AM
  #54
Blackbird CPV35's Avatar
Blackbird CPV35
the stock ecu cant read boost, it just meters air through the MAFS and im guessing they just offset the voltage when they flash it. When you use and aftermarket ecu such as the utec, it gives it the ability to run on speed density instead of mafs voltage so you can actually control injector pulse width relative to rpm and load rather than just tricking the ecu into thinking voltage is lower.
much more accurate and stable imho
Old Jul 3, 2007 | 08:48 AM
  #55
Triple8Sol's Avatar
Triple8Sol
I predict that one of two things will happen...these guys will post a thread about how their motor went BOOM....or they will never be heard from again. Either way...good luck!
Old Jul 3, 2007 | 08:57 AM
  #56
Alberto's Avatar
Alberto
Cranky FI Owner
Personally having a TN reflash that on MY car never ran right-likely due to my additional mods making it lean, I will say this.... I know Technosquare has a few guys in PR tuned @ 8psi on Greddy kits with no issues (a few on here who I havent seen in a while), and I know those guys run their cars hard. If you flash all 3 of the ECU's maps the timing wont be funny it will always be the same parameters. I dont think its the best option, but I do believe it can be done in most stock block cases with "success"
Just my 2 cents
Old Jul 3, 2007 | 09:14 AM
  #57
zzerotwosixty
They told me they're still using the MAF and O2 sensors. My AFR is a flat 11 within a couple of tenths (+ or - .2). With the ss box piggyback that had a boost sensing connection my AFR was all over the place between 9 and 12 AFR. What is speed density? What sensor does it hook up to. I have an 05 with the wideband O2 sensors. That could make all the difference. I don't know. Doesn't the UTEC only adjust timing +-2 degrees. That's not much.
Old Jul 3, 2007 | 09:17 AM
  #58
failsafe306's Avatar
failsafe306
You're thinking of the Cypher.
Old Jul 3, 2007 | 09:31 AM
  #59
zzerotwosixty
Could be. That's why I asked, instead of making an uninformed statement.
Old Jul 3, 2007 | 09:56 AM
  #60
Blackbird CPV35
no you can basically do whatever you want with timing on the UTEC
