Cooling Mods
Old Jan 23, 2008 | 07:59 AM
  #41
iStan's Avatar
iStan
ZR
While inserting the fitting for the hoses, the mf'er just cracked.
Old Jan 23, 2008 | 08:47 AM
  #42
Quamen's Avatar
Quamen
Does anyone know how those fans flow compared to stock? More CFM?
Old Jan 23, 2008 | 08:48 AM
  #43
iStan's Avatar
iStan
ZR
It definately is more CFM, how much more I'm not sure.
Old Jan 23, 2008 | 08:58 AM
  #44
Quamen's Avatar
Quamen
Not even kidding these fans would fit perfect on my radiator. $100 more then cheap JEGS fans but they would most likely be worth it. They would flow less CFM though. I think the JEGS are rated at 1560CFM a piece. I wonder if the shroud would be the bigger benefit for my setup though....
Old Jan 23, 2008 | 09:08 AM
  #45
iStan's Avatar
iStan
ZR
1560 Max? These are rated to 2500max. They definately pull a lot more than the stock and I have not run into any problems running these. The Original Post has the wiring diagram link for it as well. It's also available in black for like $20 less. Link
Old Jan 31, 2008 | 10:23 AM
  #46
TTRANK's Avatar
TTRANK
Great job. I'm going to install the same fans on my AMS with a custom shroud.
In your search did you happen to find any sandwich plate adapters that also had ports for pressure and temp sensors? I can't seem to find one anywhere but ebay which scares me for parts like that.
Old Jan 31, 2008 | 10:45 AM
  #47
iStan's Avatar
iStan
ZR
I know Greddy makes the Temp Sensor sandwhich. I never paid attention to oil pressure because I already have one in the Z. Driver might be a better source to see what other Gs are using... Oh yeah, driver is down.
Old Feb 1, 2008 | 01:02 PM
  #48
TTRANK's Avatar
TTRANK
Yeah I don't know what to do...
I found a decent looking oil cooler kit on ebay that has the plate with two 1/8" ports for sensors but I'm scared to buy an oil cooler on ebay.
Old Feb 1, 2008 | 02:03 PM
  #49
NETSHARK's Avatar
NETSHARK
GReddy makes one check this out
http://www.z1auto.com/prodmore.asp?m...ne&prodid=1143
Old Feb 1, 2008 | 02:46 PM
  #50
iStan's Avatar
iStan
ZR
Per Z1
This allows you to quickly and easily install an oil temperature and/or oil pressure gauge to your 350Z or G35 without having to drill and tap for sensor locations.
?? It may work.
Oh Tim, which fans are you talking about. The ones from Summit like mine or the ones from Jegs like Quamen?
Old Feb 2, 2008 | 01:49 PM
  #51
TTRANK's Avatar
TTRANK
I got a set of FAL's too. I was looking at the dual Spal ones but they are just too much $ for what I use my car for.
Old Feb 2, 2008 | 01:51 PM
  #52
TTRANK's Avatar
TTRANK
Originally Posted by NETSHARK
That's just what I was looking for. But here is the issue. I can get that for $65 + $10 shipping or I can get this complete oil cooler kit for ~$150 shipped.
http://cgi.ebay.com/ebaymotors/NEW-P...2em118Q2el1247
What do you guys think? I know it's not the best but anything would help and I'm not planning on getting a $400 oil cooler.
Old Feb 2, 2008 | 02:36 PM
  #53
mw9's Avatar
mw9
thanks for the info, it will be useful this track season.
Old Feb 2, 2008 | 07:53 PM
  #54
iStan's Avatar
iStan
ZR
I pieced my oil cooler together. I suppose you can run the Temp/Pressure sensor adapter and the oil cooler adapter together. May want to RTV the hell out of it for safe measure though.
The fittings were relatively cheap (Checkers/Kragen auto parts for Russell fittings) and same for oil lines. I'm just weary of ebay parts. Unless you know specifically what is in the kit.
Old Feb 9, 2008 | 05:19 AM
  #55
NETSHARK's Avatar
NETSHARK
yes you can according to Dave
Originally Posted by Dave 90TT
It can.
You can also keep the warmer/cooler on. I have two sandwich plates (one Greddy for temp and pressure sensors, and one Mocal thermostat plate for my oil cooler), and the stock warmer/cooler. Clearance is a bit tight when changing the oil filter, but still possible.
https://my350z.com/forum/showpost.ph...7&postcount=14
Old Jun 13, 2009 | 07:48 AM
  #56
COJ_General's Avatar
COJ_General
subscribing
Old Jun 13, 2009 | 10:30 AM
  #57
iStan's Avatar
iStan
ZR
What do you need? I haven't really changed anything up in quite a while.
Old Jun 13, 2009 | 01:25 PM
  #58
BrazenZ's Avatar
BrazenZ
Originally Posted by DSport G35
If you haven't installed the fans yet I would return it and buy Sharif's(Forged Performance) new upgraded fans and custom radiator shroud. You can search for the recent thread on his setup.
Are you sure you don't mean GTM shroud and cooling fans? Of all the cooling mods that I have done, external oil cooler, pathfinder rear cooling mod, Koyo 38 mm radiator, the GTM shroud and SPAL fans with the SPAL PWM controller has made the biggest difference. My Z would normally run 205F to 215F before and now never gets above 195F.
Stevo Z
Oct 3, 2015 09:14 PM
SharX59
Sep 30, 2015 10:54 AM
Tochigi_236
Sep 27, 2015 03:40 PM
