APS SG 350z "Service engine soon"
Old Jul 12, 2007 | 06:36 AM
cd001111's Avatar
cd001111
Default APS SG 350z "Service engine soon"
Hi all after using my 350z with the APS SG mod for over a year, the idiot light popped on. I removed it a few times over the day but it always returned. The codes point to Air Fule mixture, Ive replaced the stock air meter for $250 with no luck there, if anyone has any suggestions I need em, I don't want to start swapping parts.
CD
Old Jul 12, 2007 | 01:50 PM
VIZAGE's Avatar
VIZAGE
Welcome to FI. Very common if you search. Could be an O2 sensor or something else very simple. Do you have a wideband? If so what's it running? I've been throwing O2 codes basicly since day one. I just don't worry about it know more, as long as my A/F are good. But that's me.
Old Jul 12, 2007 | 08:52 PM
cd001111's Avatar
cd001111
Thanks for the help, Yes, I have the Innovate wide band A/F along with a Boost gague and a EGT. The A/F seems normal at idle it's steady around 14.5 and I haven't been driving it hard. At WOT, I can't be looking at guages I'm kinda busy if ya know what I mean. Did your car's indicator just pop on after driving a few 1000 miles or did it throw codes from jump street?
Thanks again
CD
Old Jul 14, 2007 | 07:32 PM
yoma's Avatar
yoma
My CEL light has been on since day one, but I'm without cats. Running the same at Idle or normal driving, roughly 14.5, under boost about 11ish
Old Jul 18, 2007 | 02:12 PM
cd001111's Avatar
cd001111
Default Same here no cats
Hi Guy, same here no cats APS down pipes. What codes is/are the ECU dumping? What has your tuner told you? Has your car ever been running rich? and if you could tell me the RPM when the code is dumped I would appricate it. On a hunch (and APS installer advice) I'm replacing the upper pair of O2 sensors with OEM Nissan parts (when the dealer gets them).
Thanks
CD
APS SG Kit
Full off road 2/1/2" dual APS Exhaust
APS Tall Boy
Wide band O2 sensor, Boost and EGT guages all within normal ranges
Old Jul 18, 2007 | 02:30 PM
kevin8086's Avatar
kevin8086
is there a way to get rid of the o2 code if your not running cats?
Old Jul 18, 2007 | 05:11 PM
yoma's Avatar
yoma
Thanks
CD
APS SG Kit
APS Tall Boy
I doubt that we can eliminate the CEL, that's OK, it's going to signal without cats. I know I'm running moderately rich because of the tune; I think it's probably "safer" being too rich, as apposed to being too lean. A fair trade off of FI. Someone correct me if I'm wrong
Old Jul 18, 2007 | 05:12 PM
yoma's Avatar
yoma
+1
bcoffee20
Nov 19, 2015 06:39 PM
_koubie_
Sep 20, 2015 06:34 PM
