high oil pressure
Old Jul 19, 2007 | 08:28 AM
jwttz's Avatar
jwttz
Default high oil pressure
So I hit a bump yesterday and hit the chassis and today I hit the same spot except it sparked this time. Finishing my drive to work I noticed that my oil press. was above 120 and at idle its like 115. I got to work and looked under my car to find that I scraped the sway bar and dented the oil pan slightly. The oil cooler lines were fine and no oil is leaking and I still have oil so is it possible that I damaged an oil pick up or something when I hit? any help would be appreciated.
Old Jul 19, 2007 | 05:42 PM
vqturbotec's Avatar
vqturbotec
When you come by tomorrow we will check it out.Didn't you have the same problem before.
Old Jul 19, 2007 | 06:21 PM
TheCajunStyle's Avatar
TheCajunStyle
115psi at idle is not good. should be about 14psi.
p.s. watch out for that bump!
Old Jul 20, 2007 | 08:25 AM
plastiketa's Avatar
plastiketa
try tapping on the oil gauge. I get the same reading from time to time and after a tap on top of the gauge, the needle drops dramatically to the proper reading.
Old Jul 20, 2007 | 08:30 AM
jwttz's Avatar
jwttz
Found the problem. The oil pres. sending unit is bad. really quick fix.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
