My Gauge Choices Ok?
Old Jul 22, 2007 | 05:07 AM
jining's Avatar
jining
Default My Gauge Choices Ok?
Curious if this is the smartest way to go if I have 4 gauges to work with.
A/F
Boost
Oil Pressure
Oil Temp
The A/F is autometer and the other 3 are Defi BF Amber.
Curious if Fuel Pressure would be a better idea then either Oil Pressure or Oil temp, since I am having a CJM Stage 2 Fuel System installed.
Thanks for the input.
Old Jul 22, 2007 | 05:09 AM
Jay'Z's Avatar
Jay'Z
Id rather get fuel pressure than oil pressure because the oem gauge is pretty damn accurate! .. Id rather u not waste ur money on double gauges like i did.....
Old Jul 22, 2007 | 05:48 AM
twenzel's Avatar
twenzel
CJM comes with a fuel pressure gauge on the FPR. You can't see when you are driving obviosly, but the A/F gauge should tell you if you are leaning out.
Old Jul 22, 2007 | 06:10 AM
Cube's Avatar
Cube
Based on his signature, I'd say he didn't have an oem oil pressure gauge.
How about EGT? Not important?
Old Jul 22, 2007 | 06:15 AM
Jay'Z's Avatar
Jay'Z
i have never been in an 03 base.. but u telling me they dont have an oem oil press gauge/volt/whole bunch of **** gauge/ ..
Old Jul 22, 2007 | 06:27 AM
gqong's Avatar
gqong
I think he has a G..G's are not equipeed with oil pressure gauges
Old Jul 22, 2007 | 06:58 AM
synth19's Avatar
synth19
I have the EXACT same setup. I would rather get the innovate wideband instead of the A/F from autometer. I choose oil pressure because I replaced all my stock gauges for aftermarket ones.
A/F
Boost
Oil Pressure
Oil Temp
Old Jul 22, 2007 | 07:00 AM
Cube's Avatar
Cube
Ding ding ding
Old Jul 22, 2007 | 07:03 AM
Bullitproof's Avatar
Bullitproof
Get a wideband. a/f guages are soooo 1990's
Old Jul 22, 2007 | 07:09 AM
Jay'Z's Avatar
Jay'Z
Ding ding ding
Ok, thanks for the lesson in smartassademics.. BTW no where in his sig does it say he has a fucking G..
Old Jul 22, 2007 | 07:18 AM
fklentz's Avatar
fklentz
I put a PLX dm-100 connected to 2 wideband sensors and 2 egt sensors, one for each bank. They are pretty easy to set up, a little expensive but they give you so many choices to configure and re-configure gages.
http://www.plxdevices.com/
Old Jul 22, 2007 | 07:54 AM
Cube's Avatar
Cube
HMMMM OKAY, HE HAS A Z COUPE?
Hehe I'm just messing with ya man relax.
Old Jul 22, 2007 | 07:58 AM
Cube's Avatar
Cube
So is PLX AFR monitoring in GENERAL the +/- 1.0 like someone posted about the different AFR gauges?
I had and old M-250 with a 52mm gauge and that thing was pure crap. Has PLX improved their stuff?
Old Jul 22, 2007 | 08:03 AM
Jay'Z's Avatar
Jay'Z
uh......... check the link.. neva heard of a z coupe..
http://autos.yahoo.com/nissan_350z_coupe/
Trust.. I didnt take u serious..
Old Jul 22, 2007 | 08:04 AM
Cube's Avatar
Cube
Umm what I meant was (in sarcasm) ... what other type of Z is there? Z Sedan?
But aaanyways, PLX?
Oil pressure gauge vs fuel pressure gauge?
Fuel pressure gauge can be mounted inside the engine bay, but so can the oil pressure gauge.
Old Jul 22, 2007 | 08:56 AM
cubu's Avatar
cubu
Z coupe, Z roadster
Old Jul 22, 2007 | 09:02 AM
Jason333's Avatar
Jason333
hi
After asking a few shops and getting other members opinions, i think you really only NEED a A/F and a boost gauge. You can have as many as you like to feel safe. but i think you only really NEED these 2.
Old Jul 22, 2007 | 09:16 AM
Cube's Avatar
Cube
Originally Posted by cubu
Z coupe, Z roadster
Ok you got me
Jason, what about fuel pressure or oil pressure... in the event that your oil pump sh*ts itself?
Old Jul 22, 2007 | 10:22 AM
Jason333's Avatar
Jason333
hi
Ok you got me
Yeah like i said "if" you have the pod. The Z's have an oil gauge, and I THINK you can see fuel pressure change your a/f's if you are having an issue. I could be wrong though.
*edit*
i didn't state before, but if you have a pod
Old Jul 22, 2007 | 10:36 AM
fklentz's Avatar
fklentz
It is a true wideband gage, under WOT mine reads between 11 and 12 and shows between 14 and 15 at cruise speeds.
This is the first A/F gage I've had, as far as I know so far it has been pretty accurate, the sensor is a bosch. I only have one DM-100 display now, once they release the fuel/oil pressure sensors I plan on installing 2 more in the gage pod on the dash. Oil Pressure, Fuel Pressure, Intake air temp, oil temp, data logger and OBDII. I may even have transmission and differential temp.
