ever take your vortech bypass valve apart?
Old Jul 28, 2007 | 04:56 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Default ever take your vortech bypass valve apart?
Has anyone done this? i want to take mine apart so i can powder coat the aluminum part that is not blue.
if you have done it, as it easy? any special instructions?
Where can i get a replacement? are there any substitutes? its hard to find a bypass valve.
Old Jul 28, 2007 | 06:50 PM
sentry65's Avatar
sentry65
the burninator
why make it blue? you can't even see it
Old Jul 28, 2007 | 08:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
so what, its what i want to do.
Old Jul 28, 2007 | 09:41 PM
iceagetlc's Avatar
iceagetlc
Well I disagree.
Old Jul 29, 2007 | 05:27 AM
QuadCam's Avatar
QuadCam
it should come apart without much trouble......
I have taken apart my Greddy RS BOVs a few times.
Old Jul 29, 2007 | 05:32 AM
booger's Avatar
booger
Yes I have had mine apart . Its simple and you will need one of them tools to remove [ I think its called ] a compression ring
Old Jul 29, 2007 | 05:47 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
thank you booger and quadcam!
Old Jul 29, 2007 | 07:16 AM
Quamen's Avatar
Quamen
you should be able to get a tool for removing large inside retaining rings and it will come apart.
I do believe that you can use a number of diffenet valves tough to replace it. I believe the Tail blow off valve works and I would think that the HKS SSQV would work do to its design.
Old Jul 29, 2007 | 07:21 AM
booger's Avatar
booger
retaining ring...lol thats the name of it .
When I went to the T-trim blower , I replaced the spring inside to a lighter one . I need to go to the bigger ByPass valve now though .
Old Jul 29, 2007 | 07:38 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
i thought bypass valves were different then blow of valves. Dont they work in reverse?
that retaining ring is huge!
and the 6-7 threads showing, that should be after the nut is tightened right?
Old Jul 29, 2007 | 08:09 AM
Quamen's Avatar
Quamen
Bypass valves and blowvalves are differnt. however, that does not mean that a blowoff valve with a pull type design such as the HKS SSQV or the synconic blowoff valve wouldn't work.
Old Jul 29, 2007 | 08:59 AM
QuadCam's Avatar
QuadCam
bypass valves usually have softer springs so that they'll be open under all vacuum conditions.... other than that, they serve the same purpose as a BOV. Since the SC is always spinning, the bypass valve needs to be open at all vacuum conditions to vent or bypass (depends on routing) the excess air being forced out of the blower.
I modded my Greddy RS BOV to single springs so that they upon up under vacuum only...... So,........I guess I have Greddy RS Bypass valves now.. I have no issues with them opening up under boost either. and they sound better than stock BOVs
Old Jul 29, 2007 | 09:18 AM
booger's Avatar
booger
I tried one spring in the greddy RS BOV and couldnt get it to work....hmmm. Maybe I used the stronger of the two springs .
Old Jul 29, 2007 | 02:16 PM
QuadCam's Avatar
QuadCam
yes...you do use the stronger of the 2 springs (keep the outer spring, take out the inner spring.)
Old Jul 30, 2007 | 10:42 PM
Quamen's Avatar
Quamen
This is why blowoff valves like the HKS SSQV and synchronic should work also. They are side pull valves and there for although they have a boost signal pushing them shut it is not really necessary because the boost pressure in the pipe is not pushing in the direction of valve travel like your typical blowoff valve.
Old Dec 20, 2007 | 09:29 PM
Everybodywildou's Avatar
Everybodywildou
With the HKS, would I need to remove a spring too to use it?
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
allmycarsdie
May 13, 2016 04:38 PM
Calinismo350z
Sep 14, 2015 04:04 PM
