APS Extrem kit on STOCK motor 2006
Old Jul 29, 2007 | 07:37 AM
Julian@MRC's Avatar
Julian@MRC
Default APS Extrem kit on STOCK motor 2006
We recently installed an APS extreme turbo kit on a stock motor 2006 350Z. We had to make modifications to the steering knuckle to make it fit, but the end result was worth it. We opted for the APS Extreme because the customer wants to build the motor in a year or two, and the APS already has the bigger BB turbos and the fuel system to do the job. We also added the tall boy plenum and the 3" exhaust, which I never heard on a higher compression stock motor, and it sounds SICK! Here is the Dyno, we made over 400hp at only 5PSI!! Once again these are standard DJ corrections, and our dyno is within 5 whp at these power levels of the local DJ.
Old Jul 29, 2007 | 07:52 AM
JRoC's Avatar
JRoC
wow
Old Jul 29, 2007 | 08:00 AM
Mike Wazowski's Avatar
Mike Wazowski
great numbers, but basically he will be building his motor sooner than 1-2 years because NO ONE can keep from turning up the boost. LOL
blueper4mancez's Avatar
blueper4mancez
damn... look at the curve
Old Jul 29, 2007 | 08:49 AM
plumpzz's Avatar
plumpzz
perfect torque curve. Is that lump at the end tuning issue or is it normal?
Old Jul 29, 2007 | 08:54 AM
QuicksilverZ33's Avatar
QuicksilverZ33
nice!
RBlover69's Avatar
RBlover69
nice revup numbers
Old Jul 29, 2007 | 08:59 AM
boostintt's Avatar
boostintt
holy cow... 5psi. nice numbers
Old Jul 29, 2007 | 09:07 AM
RBlover69's Avatar
RBlover69
Question are the steering modifications due to the fact that its a Rev-up motor.
Old Jul 29, 2007 | 10:28 AM
chris'smax's Avatar
chris'smax
No it is due to the fact that it is the rev-up motor and that it is a 06. They switched the steering racks in 06. Not sure if it applies to the 06 autos w/ the 287hp motor.
Old Jul 29, 2007 | 10:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Wow, sick numbers for 5psi...running not so conservative timing?
Old Jul 29, 2007 | 10:36 AM
CraZ33Y's Avatar
CraZ33Y
woooow this very nice..
Old Jul 29, 2007 | 11:15 AM
r0mey's Avatar
r0mey
its so hard to resist that urge
Old Jul 29, 2007 | 11:43 AM
Rob10_99's Avatar
Rob10_99
Nice for 6psi!
Hitting boost(full) around 4k better sound mean.
Old Jul 29, 2007 | 11:56 AM
BabyZiLLa's Avatar
BabyZiLLa
Little info on the tune? As above is this some agressive timing?
Im aiming for 4-450whp myself. If i can do it at 5psi thats sick.
Old Jul 29, 2007 | 01:07 PM
tonester1011's Avatar
tonester1011
CF God
nice #'s as usual!! but what about tony??
Old Jul 29, 2007 | 01:19 PM
Miami-Z's Avatar
Miami-Z
would the numbers be close that on an 03 motor?
Old Jul 30, 2007 | 03:34 AM
Julian@MRC's Avatar
Julian@MRC
To answer some questions...
1) Sterring knuckel modifications were made to make it fit..We used some of Sam@GTM's insight and made some of our own additional modifications.
2) conservative tune, no more than 17 degrees peak timing..Just big turbos on a high compression motor.
Old Jul 30, 2007 | 07:28 AM
Oleg's Avatar
Oleg
I'm jealous...
Old Jul 30, 2007 | 07:35 AM
danisr1's Avatar
danisr1
Sleeps in 350Z
i had the same issue with the knuckel on mine, and put in an 05 knuckel but now have no power steering at low speeds, is the knuckel mod on the 06 easy to do or not?
