Forge actuator spring rates
Old Jul 30, 2007 | 06:20 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
will the aps turbos even flow to 20 psi? where do they max out?
Old Jul 30, 2007 | 06:22 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
They will spool past 20psi, but wont make much more power past 20psi. 18-19psi is the sweet spot, in terms of efficient airflow.
Old Jul 30, 2007 | 06:23 PM
rcdash's Avatar
rcdash
Originally Posted by Audible Mayhem
yes but if you hook the boost line up straight to the ports on the actuator with no boost controller, you will make the least amount of boost possible.
internal and external wastegates are exactly backwards of each other when it comes to boosting and boost controllers...
ok, sorry - that helps clear things up - I thought you all were talking internal wastegates...
Just want to clarify that with a good electronic boost controller, an internal wastegate can go as high as the boost controller can withstand, yes? The internal wastegate only sees atmospheric pressure until the boost controller decides to allow any flow at all, correct?
Old Jul 30, 2007 | 07:20 PM
BrianLG35C's Avatar
BrianLG35C
Originally Posted by Sharif@Forged
With a built motor, it definately comes down to red or yellow. Blue is going to make 20psi plus...that's a nasty spring.
So what's the minimum blue will make?
Old Jul 30, 2007 | 07:28 PM
tig488's Avatar
tig488
19...well when you say make, 19 is the lowest you can technically run, if you run just spring pressure, the minimum is 19 at WOT. now, you can make lower, if you only go half throttle, but who wants to do that? LOL.
Old Jul 31, 2007 | 06:52 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Originally Posted by leeboyNY
Wow! You only get 10~11psi with boost controller off with the red spring?? I thought Zivman was getting like 13psi with BC off... Too many contradicting stories... This is what I'm concerned with the most... I want to be able to lower the boost to 13~14psi with the red spring, but I'm not sure if that's possible.
it all depends on the preload created when tightening the plunger into the actuator...meaning, the plunger has a threaded shaft, the further the shaft is threaded into the actuator arm, the tighter the wastegate is pulled shut,= the higher base boost pressure it will create, one can differ 1-2 psi just on the tension created as explained here...
so the variance comes from the fact that this is not an exact science with setting an internal wastegate/actuator setup...this is the reason some don't like the aps kit, I have mastered swapping springs with my turbos and actuators in the car, take sme less than 2 hrs to swap em out..I have done it a few times, and have it set up exactly how I like it
TODD
Old Jul 31, 2007 | 06:58 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
another note: we did tons of bench testing with the aps turbo/forged actuators to attempt to "set" the boost pressure before putting the turbos back in the vehicle, conclusion--> not accurate..it will give you a gross ballpark, but in no way will simulate the exhaust flow, backpressure, etc that is created in a real world situation..so, as everyone has unanimously stated, go with the red spring and save yourself from having to swap springs several times...
tighten the plunder rod at least 4-5 threads in, just tight enough so you can put the actuator cap on without it touching the plunger, that will be the least ammount of tension you can set with the red spring--> will/should yield between 10/11-13 psi with the bc off
Old Aug 7, 2007 | 06:20 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
Tig,
I'm looking at the spring ratings written on the box, and it says:
Green: 5-10
Yellow: 9-15
Blue: 14-18
Red: 19-24
Red is rated at 19psi to 24psi!!! When I press on the blue and the red spring, I can definitely tell that the red spring is stronger than the blue. Perhaps forge motorsports changed the spring color and I have the old one?? Hmm...
Old Aug 7, 2007 | 07:07 AM
BrianLG35C's Avatar
BrianLG35C
Tig,
Green: 5-10
Yellow: 9-15
Blue: 14-18
Red: 19-24
That is exactly what I understood to be the facts as well. I'm glad my tuner suggested and went with blue springs.
Old Aug 7, 2007 | 11:58 AM
tig488's Avatar
tig488
thats right , i had them backwards.
Old Feb 25, 2009 | 01:36 PM
nightcrawler_8's Avatar
nightcrawler_8
hi guys.. contacted forge UK.
and they confirmed that the yellow spring is 5-15.. :S i am confused here
