when to change spark plugs
Old Aug 1, 2007 | 08:22 PM
andyisphat2004's Avatar
andyisphat2004
Default when to change spark plugs
I found alot of posts about what plugs people are using them, but how often shoudl they be changed. RUnning TN kit. Also seems like it is getting harder for my engine to turnover, could spark plugs be the cause?
Old Aug 1, 2007 | 09:13 PM
go-fast's Avatar
go-fast
higher cyl pressures consume plugs, pull one and see what it looks like!if you compare your plugs to a plug chart you might get some insight to your tune and engine condition.i use plugs as an early warning to potential issues and change often just as a window to whats going on.
Old Aug 1, 2007 | 09:46 PM
andyisphat2004
yeah my tuner said every 2 oil changes, i just wanted to get when everyone else is doing it
Old Aug 1, 2007 | 10:01 PM
therock2689's Avatar
therock2689
I pull them out from time to time and check how they are. Like it was said above, the plugs can tell you a lot about what is going on inside the cylinder. NOw, if your running boost or nitrous, i dont know, but just pull them out, doent take to long.
Old Aug 2, 2007 | 04:32 AM
go-fast's Avatar
go-fast
if im taking the time to check them all i replace them at the same time,besides it gives your next test or window a fresh start.every build is not the same so i would go by what the car wants,it's one place that overkill wont hurt.
Old Aug 2, 2007 | 11:35 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
With the richer mixtures people are running with FI, it would be a good idea to check them every 5000 miles, and change them every 10K miles. They are cheap, and no sense in skimping on them. In theory, Iridium plugs can last for 75K on an NA car.
Old Aug 2, 2007 | 12:43 PM
MIAPLAYA's Avatar
MIAPLAYA
I change mine no more then 15,000 miles each set.
Old Aug 2, 2007 | 12:55 PM
k3silk's Avatar
k3silk
whats the plug number again cant rem. of top of my head I have a jwt tt set up I think last time I went 1 step colder. What plug number are you guys using?
Old Aug 2, 2007 | 12:56 PM
MIAPLAYA's Avatar
MIAPLAYA
NGK LFR6AIX-11
Old Aug 2, 2007 | 12:58 PM
k3silk's Avatar
k3silk
thanks Im going to order some after seeing this thread I Reminded me time to change them out.
Old Aug 2, 2007 | 02:31 PM
thawk408's Avatar
thawk408
Originally Posted by MIAPLAYA
NGK LFR6AIX-11
I thought the 6 was the stock plug and the 7 was one step colder.
Old Aug 2, 2007 | 05:10 PM
PalFX's Avatar
PalFX
Nah...6 is one step colder and 7 is 2 steps colder. Stock is 5.
http://www.forgedperformance.com/store/home.php?cat=275
350z82
Oct 1, 2015 06:25 PM
