supercharger on an 03 Z
Old Aug 3, 2007 | 06:40 AM
zakkula's Avatar
zakkula
Default supercharger on an 03 Z
i am bout to get this 03 350z 6 speed. i want right away to get to the point, supercharging it. vortech was recommended but after i get supercharged what mods should i look into
Old Aug 3, 2007 | 06:44 AM
z350boy's Avatar
z350boy
If you want mods to compliment the supercharger you might consider:
(1) free flowing exchaust
(2) plenum spacer (5/16")
(3) Underdrive pulleys
(4) diff gear change
BTW have you looked at the Rotrex S/C ?? Very clean install!!
Old Aug 3, 2007 | 06:45 AM
SSZVirginia's Avatar
SSZVirginia
Upper and lower engine rebuild.
Old Aug 3, 2007 | 06:48 AM
coreapoc's Avatar
coreapoc
Save money. Turbo it. The supercharger eats up gained power. Beltless turbo ftw.
Old Aug 3, 2007 | 06:51 AM
zakkula's Avatar
zakkula
i mean i jus wanna put either the rotrex, stillen or vortech sc on it, dont wanna turbo it, always wanted a supercharged car, i was jus wonderin what mods would best compliment the sc
Old Aug 3, 2007 | 07:01 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
(3) is not recomended. this is a SC, it is belt driven off the crank pulley. If you underdrive the SC you will get less boost and lower your power.
Old Aug 3, 2007 | 07:02 AM
coreapoc's Avatar
coreapoc
Well the obvious intake/exhaust - most importantly brakes. No point in going fast if you cant stop safely. Pulley swap as mentioned above. Nismo sticker on the quarter panel.
Old Aug 3, 2007 | 07:04 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
hope youre being sarcastic about the intake and pulley swap. else
Old Aug 3, 2007 | 07:14 AM
HondaKiller's Avatar
HondaKiller
the stock pulley is recommended with a SC. If you want more boost, change the pulley on the SC, not the cranky pulley on the engine. Once you get the SC, the engine mangement that comes with them is usually bobo, you'll want to upgrade to a UTECH.
Old Aug 3, 2007 | 07:16 AM
fast kiwi's Avatar
fast kiwi
+1.. just get a light weight flywheel.. not underdriven.
Old Aug 3, 2007 | 07:17 AM
fast kiwi's Avatar
fast kiwi
im thinking he's very serious...
Old Aug 3, 2007 | 07:20 AM
Z04's Avatar
Z04
here we go, the old supercharger vs turbo debate
Old Aug 3, 2007 | 07:21 AM
fast kiwi's Avatar
fast kiwi
turbos suck!!!!
j/k.. lol
Old Aug 3, 2007 | 07:52 AM
z stud 13's Avatar
z stud 13
i like the looks and gains of the stillen s/c. i mean i tend to think that s/c an NA car is more reliable than turbo. just my .02 , but i fyou wana blow up your engine i recommend going turbo. ( unless you have forged internals and such)
Old Aug 3, 2007 | 08:21 AM
Shift_Z33's Avatar
Shift_Z33
I think I'd first learn to properly drive the Z in stock form. It can be quite pleasing on a track. Sometimes more power will actually make you slower around turns. Now, if you are dead set on FI, then I'd start searching old threads and reading how it all works and what all is needed since it sounds like you are new to the subject. Im tired of reading "I wrecked my Z" threads so learn something from those people; dont just throw a bunch of money at the car and expect to be able to drive it like a pro. You will get hurt.
That said, I'd go w/ the Stillen blower over the Vortec b/c centrifugal s/c's have all the cons and few pros. Stillen is linear and instant torque. As far as supporting mods go; brakes, clutch, exhaust, tires possibly, and an empty road.
Old Aug 3, 2007 | 08:30 AM
booger's Avatar
booger
I would NEVER change out the crank pulley with something lighter if your putting on a SCer
Old Aug 3, 2007 | 08:33 AM
booger's Avatar
booger
1-ok
2-ok
3- no f-cking way
4-ok
Rotrex...isnt in the USA
Old Aug 3, 2007 | 09:08 AM
doug's Avatar
doug
your post is ignorant and you should do some research before you post again.
1) there are no real gains to a stillen Supercharger.. its maybe 10 to 20 whp over bolt on's
2) i have proved in another thread that Vortech is more reliable than Stillen
3) Turbo's don't blow your motors.. bad tunes and bad installs do.. this isn't 2005 .. Turbo setups are as reliable as SC setups.
4) Built Motors still blow as do Stock Motors.
Old Aug 3, 2007 | 09:09 AM
doug's Avatar
doug
I love how N/A owners come in here and tell us to get Stillen over everything else because they are more reliable.. and when i challeged SOLO to prove it.. he couldn't.. and i found two blown stillen motors and he couldn't find 1 blown vortech
Old Aug 3, 2007 | 09:32 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
shiftz33:
please tell me a few of the cons to a centrifugal blower?
are you saying the vortech doesnt provide linear power?
