Official STS Rear Mount Turbo Discussion Thread
Old Aug 27, 2008 | 12:45 PM
  #1381
JonnyC's Avatar
JonnyC
Ah, I didn't know that the Nismo mid-pipe was the same as the stock pipe and could bolt up to the STS piping (unless I'm missing something here?).
I still have my stock (but very rusty) y-pipe and mid-pipe, so I'll just use that I guess. Yay - more funds to recoup!
Old Aug 27, 2008 | 12:46 PM
  #1382
athenG's Avatar
athenG
Originally Posted by JonnyC
Alright guys, getting closer to pulling the trigger on this.
What mid-pipe do you guys go with? I currently have a Stillen y-pipe in combination with a Nismo exhaust, so I'm not sure if I'll be keeping the y-pipe or selling it with my Nismo. If I do keep the y-pipe - would I want to get a mid-pipe custom bent w/ resonator? Or is there one I could buy that could directly swap with the stock mid-pipe?
I used to have the link for the Mid-pip resonator but Magnaflow keep changing their site PM Goosegoose coz he has a magnaflow midpipe resonator and he swear that it made his car quieter w/o affecting performance. Ahsmo do have a TP, Nismo Y and Nismo Midpipe and his boost seem to hit much later than us. Look at the dynos on the first page and you'll see that Ahsmo's peak TQ hit much later than us (around 4500rpm) I hit my peak tq at 9psi at 3700rpm with just Testpipe and stock Y-pipe and mid-pipe and pretty much the same with Teg's and Daniel's dynos. I wouldn't open the exhaust system to much with Rear-Mount.
Old Aug 27, 2008 | 12:53 PM
  #1383
Ahsmo's Avatar
Ahsmo
Imakecopies
No it does not directly bolt up, I had to cut it appart and reweld. Certainly not worth the trouble, and as atheng stated, my boost comes on much later.
I have been considering going back to a stock midpipe with a nice resonator.
Old Aug 27, 2008 | 02:37 PM
  #1384
Boozt's Avatar
Boozt
My speedshop (APR in Redding Cali) welded up new pipe for me with a resonator......I had ditched the stock exhaust for an Injen set up but sold the Injen when I got the STS. Pull the trigger Johnny C!!!! You won't be sorry - Jim
Old Aug 27, 2008 | 02:53 PM
  #1385
JonnyC's Avatar
JonnyC
Well screw it - I'm going to start pulling the Vortech off tonight. Who knows what bad things I might find, which could change the situation totally (yes, I always fear the worst).
Old Aug 27, 2008 | 04:21 PM
  #1386
Boozt's Avatar
Boozt
If or when you go turbo.........You will not be able to the grin off your face.
Old Aug 27, 2008 | 04:53 PM
  #1387
WASHWIZ's Avatar
WASHWIZ
I have TP, AAM Y-pipe, and the OEM midpipe. I don't have a graph, but I believe I'm hitting full boost @ about 4000.
Old Aug 28, 2008 | 12:37 PM
  #1388
350Z400rwhp's Avatar
350Z400rwhp
Going Turbo Johnny?
Old Aug 28, 2008 | 01:21 PM
  #1389
JonnyC's Avatar
JonnyC
Originally Posted by 350Z400rwhp
Going Turbo Johnny?
Don't know yet - have to make a decision by tomorrow. I want to, but the bank account isn't too happy with me.
Ok guys - does anyone know how the PCV system works? Where does the driver's side breather tube hook up to? It doesn't seem to say in the install manual.
And, I already have a fitting tapped into my upper pan - can I run the oil return line to that instead of through the cross breather tube up top? I would have to cap that off then.
Old Aug 28, 2008 | 04:39 PM
  #1390
DanielW's Avatar
DanielW
+1 I would recommend the invidia test pipes to stock y pipe and mid pipe setup. I'm sure you sacrifice a small amount of power on top end but it really helps power kick in earlier.
Old Aug 28, 2008 | 04:41 PM
  #1391
DanielW's Avatar
DanielW
The invidias are 2.25" diamater which is smaller that most others at 2.5" btw
Old Aug 29, 2008 | 05:49 AM
  #1392
athenG's Avatar
athenG
Call sts for tapping into your lower oil pan. STS has an Oil pump that I think tap into the driver side pcv for the oil return.
Old Sep 2, 2008 | 01:58 PM
  #1393
JonnyC's Avatar
JonnyC
Well, I pulled the trigger today on a Tuner Kit. Should have the kit in 2-3 weeks.
So the things I will need right away...
440cc injectors (well, once I get my next paycheck )
Base maps - Anyone have the base maps that came on your UTEC with the kit? STS is unable to provide that w/o a price (should have figured).
Sometime in the future...
TurboXS BCS (will run on waste gate spring just to start off)
Meth kit (straight water probably)
Old Sep 8, 2008 | 07:37 PM
  #1394
JonnyC's Avatar
JonnyC
Are you guys running an Oil Cooler? I was thinking I should now that I'm going turbo, but with my pan spacer, the remote turbo, I'd already be running 6.5+ qts of oil.
Old Sep 9, 2008 | 03:46 AM
  #1395
goosegoose's Avatar
goosegoose
I have an oil cooler. Cheap insurance.
Old Sep 9, 2008 | 07:17 AM
  #1396
Ahsmo's Avatar
Ahsmo
Imakecopies
Awesome. Someone should have an okay map to try. I have a XS BCS if you want it. I dont use it.
Old Sep 9, 2008 | 08:54 AM
  #1397
DanielW's Avatar
DanielW
I would seriously consider an ebc right off the bat with this kit. It has more trouble than most at making full boost in first three gears/
Old Sep 9, 2008 | 09:29 AM
  #1398
JonnyC's Avatar
JonnyC
Yeah, I'm pretty sure I'll go with one right away now. I was just thinking about avoiding it at first for simplicity's sake.
So were you running an oil cooler as well? Trying to hear from the STS owners on this.
Old Sep 9, 2008 | 12:06 PM
  #1399
athenG's Avatar
athenG
good for you, I don't have an oil cooler and I seem to be fine... My oil analysis seem to be fine too... Are you going to be tracking the car often? if not then I would use the extra $$ somewhere else.
Old Sep 9, 2008 | 12:28 PM
  #1400
DanielW's Avatar
DanielW
I didn't have an oil cooler and I ran it HARD at Z dayZ with 25k miles on the kit and motor. I also did about 20 passes at rockingham dragway after i first turbocharged the car with no problems
