Official STS Rear Mount Turbo Discussion Thread
Old Nov 7, 2014 | 10:59 AM
  #3001
athenG's Avatar
athenG
I feel bad for my G35 since i haven't driven it much anymore since the BBK upgrade. I feel like selling it so that someone can enjoy it more. I just traded my 2014 Cayenne GTS and got me the 2014 Maserati GranTurismo Sports.. Now my G35 will be like the forgotten child..
Old Nov 11, 2014 | 08:43 AM
  #3002
kpturbo's Avatar
kpturbo
Hi guys
Could someone send me a pdf with manual to the STS kit??
Send me a PM so I can give you my mail adress.
Thanks
Old Nov 12, 2014 | 09:43 AM
  #3003
athenG's Avatar
athenG
send me you email and I'll send a copy.
Old Feb 17, 2015 | 01:05 PM
  #3004
Gangster35's Avatar
Gangster35
This will only bolt up to the stock exhaust correct? I have a stollen exhaust, so I'm going to need to cut and weld some new flanges and pipes on then?
Old Feb 17, 2015 | 01:52 PM
  #3005
Conway_160's Avatar
Conway_160
Its supposed to conect to stock but with a good exhaust shop they can make it work.
Old Feb 17, 2015 | 03:23 PM
  #3006
Gangster35's Avatar
Gangster35
Alright I guess I'll make it work! Thanks! What kind of hp can you get out of these? I've got ported heads, 272 cams, wiseco .020 over pistons, fully built bottom end, STRUMP headers, and ART pipes. What do you think I can push out of this kit? Hoping for 500whp. Will the non upgraded turbo with 450cc injectors hit the 500whp kit on pump at say 15-20psi?
Old Feb 17, 2015 | 03:41 PM
  #3007
Conway_160's Avatar
Conway_160
Im not sure but you will need to upgrade your injectors if your only using 440's. Those should max out around 450'ish on pump.
Old Feb 18, 2015 | 01:25 PM
  #3008
Gangster35's Avatar
Gangster35
What are you guys running for mufflers? Is it too loud?
I've got headers, and ART pipes, and was wondering if I should put a muffler or a resonator in?
Old Mar 4, 2015 | 11:33 AM
  #3009
athenG's Avatar
athenG
The turbo is way in the back.. it actually replace the muffler so no muffler needed. if you want to reduce the sound then can upgrade the mid-pipe muffler to a bigger one.
Old Mar 11, 2015 | 03:39 PM
  #3010
Gangster35's Avatar
Gangster35
What kind of HP can you get out of the turbo? I've got a built block with ported heads, and 750cc injectors and a 320lph fuel pump so just wondering what can I get out of the turbo in the kit when it's maxed out?
Old Mar 13, 2015 | 10:34 AM
  #3011
athenG's Avatar
athenG
if you have a built motor then look somewhere else... stock STS kit can get you about 400whp and after that it's blowing hot air...
Old Apr 9, 2015 | 08:24 AM
  #3012
usaygo's Avatar
usaygo
Default STS installation manual
Does anyone have an STS installation manual for the HR motor in PDF?
STS hasn't answered their phone in over a month.
Old Apr 17, 2015 | 10:01 AM
  #3013
str8dum1's Avatar
str8dum1
what part are you stuck on?
Old Apr 17, 2015 | 09:40 PM
  #3014
The_Assassin's Avatar
The_Assassin
They don't make the kit for the hr...But it can however be made to fit with a bit of work.
Old May 30, 2015 | 02:15 PM
  #3015
The_Assassin
Any updates guys? Finally saved up enough money to purchase the kit. Just trying to make sure am making the right choice..I have an HR, does anyone know where I can get a 1 in 2 out intercooler?
Old Sep 1, 2015 | 05:23 PM
  #3016
skn5002's Avatar
skn5002
What are the specs on the turbo that the kit came with? It is a TO4E60 O Trim .58 AR housing correct?
Has anyone tried to rebuild their own turbo? Will this kit work?
Amazon.com: Minor Repair Rebuild Kit for OE&Performance T3 T4 Turbo Charger: Automotive Amazon.com: Minor Repair Rebuild Kit for OE&Performance T3 T4 Turbo Charger: Automotive
Old Sep 2, 2015 | 12:57 AM
  #3017
superlim9's Avatar
superlim9
S&R performance was the only company that I know of to make a single turbo for the HR and they aren't around anymore to my knowledge.
I think your looking a custom job for the STS..
message dfresh89 on here.. he modified a 370z BP kit to fit the HR
Old Sep 11, 2015 | 10:43 AM
  #3018
Conway_160's Avatar
Conway_160
Any one know what the most power put out of a rear mount is?
Old Sep 16, 2015 | 09:45 AM
  #3019
str8dum1's Avatar
str8dum1
a much as the turbo used will support. you could rear mount 2 Promod 108mm turbos, spray it with a 500shot and make 3kwhp.
Old Sep 16, 2015 | 10:21 AM
  #3020
Conway_160's Avatar
Conway_160
LOL, I just curious how far any one has pushed a Rear mount set up. I figured you could go as big as you want but I was just curious how big people have went and how bad the lag was.
