Aux Fuel Pump Relay Help Needed
Old Aug 16, 2007 | 06:30 AM
eez's Avatar
eez
Default Aux Fuel Pump Relay Help Needed
I installed my vortech sc yesterday and hooked up the negative batt term and the aux (in line) fuel pump was running. I know it shouldn't be running unless the unichip turns it on, which shouldn't happen until boost. Anyway I think the relay may be connected wrong.
I followed vortech's instructions below.
couple things about the instructions.
1. On terminal #30 it never says where to connect the 1' 14g wire (I assumed it was ground)
2. Terminal #87 goes to negative on the pump, but they told me to ground the pump to one of the mounting screws so I just grounded #87 to the block.
3. If the 12v power #86 is connected to the battery and the + on the pump, wouldn't it always see power??? (I think this is my problem)
Old Aug 16, 2007 | 07:12 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
85 and 86 are the power and ground for the relay, this lets the relay switch on and off if both are connect to 12v and ground at the same time.
30 is EITHER the power if the relay is switching something with power OR the ground if the relay is switching something with ground.
then 87 is the switch leg to whatever you are switching...
good luck!!
Old Aug 16, 2007 | 07:24 AM
eez's Avatar
eez
thanks for the help
so the vortech instructions are wrong? If 87 is to switch the pump on and off (I assume in this case they want to turn it off by removing ground) why would they have me ground the pump during the pump installation? I'm still confused.
So should i remove ground from the pump and hook it up to 87?
Old Aug 16, 2007 | 07:31 AM
Audible Mayhem
My350z
its probably for the power, you might have 30 going to the wrong place...
it says it goes to a pin on the unichip?? on the page you posted
Old Aug 16, 2007 | 07:46 AM
eez's Avatar
eez
30 is connected to the brown unichip wire
Old Aug 16, 2007 | 07:47 AM
Audible Mayhem
My350z
now do you know that the aux pump probably only comes on during boost levels
Old Aug 16, 2007 | 07:57 AM
eez's Avatar
eez
its turning on with the ignition off and the battery connected and i know that's not right so even if my statement is wrong about turning on at boost, it shouldn't be on without any ignition.
Old Aug 16, 2007 | 08:11 AM
failsafe306's Avatar
failsafe306
Diagram looks right to me. When the unichip signals the relay, it should send the fuel pump to ground (#87) and turn on. Take the fuel pump ground off the chassis and hook it only to 87. The way you have it now, you're basically hooked right up to the battery.
Old Aug 16, 2007 | 08:46 AM
eez's Avatar
eez
thanks got it. that's what vortech just told me. they have f-ed up instructions. they fail to mention that the ground to the installation screw to the pump is for non-rev up. So, right now it's always seeing ground. They are going to update their manual.
Dsowe
Feb 17, 2021 10:38 AM
kyin
Oct 15, 2015 05:54 AM
SharX59
Sep 27, 2015 09:23 AM
