car wont start after walbro 255 install, need some insight
Old Aug 18, 2007 | 07:47 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
are you doing the pump alone with nothing else at all??
or are you doing a couple things at once...??
let me know and i will figure out what is the deal
Old Aug 19, 2007 | 03:51 AM
silver nismo's Avatar
silver nismo
Originally Posted by i8acobra
Turn the key to "on" without starting it. Did you hear the pump come on? If not, it's not getting power or is bad. You will definitely hear the Walbro 255 come on. It's much louder than stock.
+100
Old Aug 19, 2007 | 04:50 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
at first it was the pump alone, on a vortech 440cc map and map 0 it wouldnt start.
now the vortech is 90% in. Im going to install the injectors and pump again and see if shell crank.
Old Aug 19, 2007 | 10:58 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
bump, about to go install my injectors and fuel pump and switch to a new map.
Car starts ok now, bit rough to get up. Run about 14.6 at idle and get richer when i rev up to 3k, less then 30% throttle.
SC is in.
No belt slippage squeeks
All lines outta the way
Bypass blows nicely(6-7 threads exposed)
Cant tell if charge pipes are all sealed since bypass is always open
Old Aug 19, 2007 | 03:33 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Injectors are in, and she ran rich, like really rich so i switched maps and now she idles at about 14.5 and then gets rich is i slowly accelerate. Whats the highest i should see on the wb under acceleration? I dont have the walbro in so i think it might run a bit lean since the pressure is lower. Going to try installing it one last time. Gotta eat first, starving!
Got a slight oil leak at the sandwhich plate plugs, going to ditch that tuesday. Gonna bring 5qt's of oil with me just in case. May swap it tonight tho, hate to have a leak, would only take a few mins to change the oil.
Old Aug 19, 2007 | 04:34 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Good luck with everything man.
Old Aug 19, 2007 | 04:50 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
i give up on this walbro, it still wont crank. Guess ill have to swap to stock in the morning and ride with that.
Old Aug 20, 2007 | 03:03 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Stock pump is back in, fresh oil and no leak now! Dont have a oil temp sensor though, gotta remedy that at my next oil change. Did all that in the dark in 55 minutes!
Off to marietta to get it tuned!
aarrgghh
May 1, 2022 11:04 AM
Ronso
Oct 30, 2015 12:39 PM
