Question about going back to stock after TN fuel pump mod's
Old Aug 29, 2007 | 03:40 PM
failsafe306's Avatar
failsafe306
Question Question about going back to stock after TN fuel pump mod's
I've decided to put my car back to stock half way through my TN kit install. I have already completed the modifications to the FPR and the plastic housing, per TN's instructions.
My question is, how bad will my car run after re-installing the stock fuel pump and injectors, but with the drilled out FPR and the 2 3/8" holes in the pump housing? Will I run super rich, or is it not gonna be a big deal?
Any help would be appreciated, as I got a quote from the dealer for $303.00 for a brand new fuel pump assembly
Old Aug 29, 2007 | 04:09 PM
350zOnJuice's Avatar
350zOnJuice
What is it you need the stock fuel pump?
Old Aug 29, 2007 | 04:12 PM
RED HOT Z's Avatar
RED HOT Z
I'd suggest buying the new assembly. You would think you would run richer because of the extra fuel getting in to the fuel pump. But then maybe you wont because you will still be using the stock fuel pump. I'm assuming the wholes are cut out so the larger warlboro can suck up more fuel but if your still using the stock one maybe it will suck up the same.
Why did you stop the install?
Old Aug 29, 2007 | 04:13 PM
350zOnJuice
^^ + 2 on why did you stop
Old Aug 29, 2007 | 04:32 PM
failsafe306
Mostly because I'm physically unable to finish it at this time (medical reasons). Also I'm thinking about either upgrading to a new 07 or 08 Z, or possibly trying a new platform all together.
In my FS add for the TN kit, I request that the buyer just swap me fuel assemblies, but if it doesn't sell soon I'll just see how it goes with the mods.
Shameless plug: TN kit with extras for sale! https://my350z.com/forum/showthread.php?t=297516
Old Aug 29, 2007 | 04:33 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
you should be fine. I ran ok on the stock pump with the modified setup. Ran rich with the 440's i had but ran fine with the stock injectors.
failsafe306
That's good to know, thank you!
Old Aug 29, 2007 | 10:11 PM
MIAPLAYA's Avatar
MIAPLAYA
I agree you should be ok. If anything I would expect the fuel pressure to be lower than normal or the same. The modification to the FPR is to keep static fuel pressure at 53 PSI with the upgraded pump. The holes in the surge cannister were to ensure adequate fuel flow to the new pump. Sorry to hear you are stopping the install.
Old Aug 30, 2007 | 05:42 AM
QuadCam's Avatar
QuadCam
the best thing to do would be to leave the walbro pump in the tank. they are only $90, so it's not much of a loss to you.
Old Aug 30, 2007 | 05:51 AM
failsafe306
Would that cause the fuel pressure to be too high with the stock injectors?
Old Aug 30, 2007 | 07:07 AM
MIAPLAYA's Avatar
MIAPLAYA
Not it would not. The modifications you made to the stock FPR would keep the static fuel pressure at 53-55 PSI. That is perfectly fine for the stock injectors using the stock map.
Old Aug 30, 2007 | 07:12 AM
QuadCam's Avatar
QuadCam
+1
Old Aug 30, 2007 | 07:19 AM
failsafe306
Thanks guys, I guess if my kit doesn't sell by the end of the week so I can just swap units, I'll just leave all in the fuel tank as is.
Old Aug 30, 2007 | 08:09 AM
phunk's Avatar
phunk
CJ Motorsports
turbonetics is still telling people to put those 2 holes in the can?
Old Aug 30, 2007 | 08:10 AM
MIAPLAYA's Avatar
MIAPLAYA
I think we are all well aware of your direction on this but no the instructions have not changed. I have never run into an issue with my fuel cannister like that and neither has Craig or several other long running Turbonetics cars that track their cars. I've run at Streets, Big Willow, Cali Speedway drag strip, canyon runs and even an autocross and never once had an issue with the fuel cannister like that. Over 70k miles now.
Old Aug 30, 2007 | 08:11 AM
failsafe306
Yes, it's in their online instructions anyway. I was told that they're fine as long as you are running the stock fuel system (no return).
Old Aug 30, 2007 | 08:15 AM
Quamen's Avatar
Quamen
I've been running the Walbro pump in my car stock with no issues for the last 2 years.
Old Aug 30, 2007 | 11:34 AM
DaveFunction2ND's Avatar
DaveFunction2ND
+1
To OP - You'll be fine with the TN modified setup and the 255 although you MAY be slightly rich up top since the factory tuning accounts for a pressure drop at ~5000+. Not enough to hurt anything just not optomized for the best power but this can easily be tuned out with UTEC/AFC/etc etc.
Old Aug 30, 2007 | 11:52 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
please elaborate, i am honestly curious.
etkms
Jun 19, 2022 06:30 PM
lolwatbro
Oct 9, 2021 04:58 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
Calinismo350z
Sep 14, 2015 04:04 PM
