AC went out today
Old Sep 1, 2007 | 02:34 PM
taurran's Avatar
taurran
Originally Posted by diwun67
Where, on 301? Were you in your Z? I saw a 2 Z's going north on 301 but didn't see a redline...and yeah it was hot
Nope you were sitting at the light on Balm Riverview and I drove by in my truck.
Old Sep 1, 2007 | 02:36 PM
diwun67's Avatar
diwun67
Ahh ok, I had just dropped off that chick I'm seeing at home. I guess you live in that area too lol
Old Sep 1, 2007 | 06:03 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
do you find it strange that you only see her at home??
Old Sep 1, 2007 | 06:05 PM
diwun67's Avatar
diwun67
Man, you're on a roll tonight!
Old Sep 2, 2007 | 12:25 PM
andyisphat2004's Avatar
andyisphat2004
if you are going to replace this yourself, i would def. buy/renta hand vacuum pump so that after you replace the line, you can check the integrity prior to reinstalling the turbo
Old Sep 2, 2007 | 12:28 PM
diwun67's Avatar
diwun67
'd just like to know how I go about making sure which line is busted without having the proper AC diagnostic equipment?
Old Sep 2, 2007 | 04:27 PM
andyisphat2004
you can buy this uv stuff you spray into the low pressure port and then look with a blacklight. The only problem is that everything is so frigin tight that it is hard to tell.
Old Sep 3, 2007 | 07:23 AM
one350zfan's Avatar
one350zfan
tuarran, I double wrapped the upper a/c line and used the clamp to hold it by the dipstick. However, I noticed on your old set-up that you had the a/c between the motor and dipstick - Which is what I should've done but how do you use the dipstick?
Anyway, mine is double wrapped w/ heat shield tape but it touches the welded protection on the down pipe. The down pipe is jet-hot coated, do you think I'll have a problem?
The lower a/c line is zip-tied away from the waste-gate relocation pipe so I don't see a problem with that one.
Old Oct 14, 2007 | 09:13 PM
tt3000gt's Avatar
tt3000gt
Well it finally happened, I was on the highway when I notice in the rearview a bunch of white smoke/vapor coming out from behind the car. I thought oh sh*t my turbo is cooked, but it suddenly stopped, and that's when my AC went hot It couldn't have happened during a hotter heatwave I'm too tired right now to jack up the car and see what happened, but I'm hoping it's the replacement AC hose that TN supplies with the kit because I have a spare (thanks chimmike ) I have my doubts it's that hose though...
fail
Old Oct 14, 2007 | 09:17 PM
diwun67's Avatar
diwun67
Originally Posted by tt3000gt
fail
Good job. You got me real good. Now I need some time to recover from the massive ownage that has been bestowed upon me by this n00b at life. Good night all.
Old Oct 14, 2007 | 11:25 PM
DMK's Avatar
DMK
fail
damn noobs.
Old Oct 15, 2007 | 06:16 AM
QuadCam's Avatar
QuadCam
well, we installed ryans kit, it was a used kit, didnt find out that the used AC line he had was busted for a couple months later when he tried to refill it...
the line that is busted is no where near anything hot...
Ryan should have waited a couple days for the right A/C line!!! My A/C line was still good.
Old Oct 15, 2007 | 06:36 AM
Audible Mayhem
My350z
thats what happens when you buy used stuff!! hehehe
Old Oct 15, 2007 | 04:57 PM
r0mey's Avatar
r0mey
post editted the senseless name calling and bashing stops consider this your warnings
Dont continue.
Old Oct 15, 2007 | 05:12 PM
diwun67's Avatar
diwun67
Jeez, sounds like someone's a tad bitter over a failed attempt at the elusive big single turbo
Old Oct 18, 2007 | 09:41 PM
350Z400rwhp's Avatar
350Z400rwhp
I'm looking at this Turbonetics kit too. Has anyone had any issues with it hurting the paint on the hood? Should I consider a turbo kit that puts the turbo down lower or behind the engine or is this heat problem manageable? I really like the TN kit but with all of this global warming going on I can't go without a/c
Old Oct 19, 2007 | 05:30 AM
taurran's Avatar
taurran
No, your hood will be fine. I even have a fiberglass painted hood and have had no issues.
Just do EXTRA heat shielding on your AC line like I mentioned above (I mean go overboard with it), and be extra careful with the routing. You should have no issues. A little prevention up front goes a long way.
Old Oct 19, 2007 | 05:53 AM
  #38
QuadCam's Avatar
QuadCam
I used a turbo blanket from Turbo logic on my TN install. that and using header wrap on all the hot pipes. It really keeps underhood temps down to a minimum.
Old Oct 19, 2007 | 02:02 PM
  #39
98intrigue's Avatar
98intrigue
I wish I did... still haven't replaced the line, haha.
Old Oct 19, 2007 | 02:39 PM
  #40
diwun67's Avatar
diwun67
hahaha, me neither, I suck...
