rough idle with new plugs
Old Sep 3, 2007 | 03:41 PM
eez's Avatar
eez
Default rough idle with new plugs
I installed the NGK iridium 1 step colder plugs and my engine seems to be running rougher (Check my sig for mods). On the other hand the car seems to be pulling better and there is more growl to the engine tone. I also noticed that I hit 8psi on the dot and before I was only hitting about 7.5...maybe I had a little leak that was fixed when reinstalling the throttle body piping.
Is the rougher idle due to the 1 step colder? should I be concerned?
edit: maybe rough idle is not the best way to describe it... The AFR and RPMs seem to be consistent but the engine is kinda shaking at low RPMs
Old Sep 3, 2007 | 03:54 PM
westpak's Avatar
westpak
SFZCC
gap?
Old Sep 3, 2007 | 04:04 PM
eez's Avatar
eez
i did not change the gap so however they came. From what i understand the LFR6AIX-11 are properly gapped from the factory.
Old Sep 3, 2007 | 04:05 PM
failsafe306's Avatar
failsafe306
Maybe the ecu just needs to relearn the idle.
Old Sep 4, 2007 | 06:38 AM
eez's Avatar
eez
after driving the car this morning I noticed it happens after the car warms up. When I am cruising at 3k RPMs there is a somewhat faint woom...woom...woom noise (sorry thats the best way I can describe it)
Old Sep 7, 2007 | 02:04 PM
eez's Avatar
eez
LOL I figured out what the problem was... I tightened the strut bar to much and it was rubbing on the plenum and thus causing a vibration/grinding noise. Guess I was so paranoid I did something wrong I failed look for the obvious. Anyway I'm glad I found it and that it was an easy fix
Old Sep 7, 2007 | 02:57 PM
SH Luciano's Avatar
SH Luciano
do you have a spacer or upgraded plenum? i fail to see how a stock strut bar can be tightened down so much it's touch a stock plenum...
Old Sep 7, 2007 | 03:23 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Glad you figured it out, 1step colder iridium plugs at stock gap should not cause any idle issues.
Old Sep 7, 2007 | 06:17 PM
eez's Avatar
eez
i have a spacer. check my sig.
liqalu04
Jan 2, 2022 12:58 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
