Back Pressure Expert Topic
Old Sep 7, 2007 | 06:09 AM
taurran's Avatar
taurran
Originally Posted by 4SHIZZIL G-SPOT
We we say ideal are we referring to installation and air flow or are we saying effeciency?
One 5" has less volume than two 3" (3+3) being 6. I no I am being picky here, trust me...I just want to learn.
So I guess with a cross pipe from one side of the manifold to the the other, the amount of usable air flow is not enough for a VQ to run single exhaust effeciently?
But if going dual exhaust, to equate to the Supra 5"....wouldnt that be dual 2.5's for the VQ?
Thanks for taking the time for my off the wall questions in advance.
You're comparing apples to oranges here. I think the comparison he made was comparing a single pipe exhaust to one that splits or converges into from one pipe to two. Example - our stock "y-pipe" cat-back exhaust.
For instance, a single 3" exhaust all the way back from the turbo outlet to the tip would flow more efficiently than a 3" exhaust that split into two 2" or 2.5" pipes. (even though the sum diameter of both pipes added up to more)
On a twin turbo setup for our car with a dual exhaust, you're in effect running two seperate "single exhausts". I say this because the exhaust streams are entirely divorced from the time they leave the heads to the time they exit at the back of the car.
Next, you're going to have to add in the actual volume of air each head/cyl bank is moving. For instance, you can have a single turbo and 3" exhaust back moving the full 3.5l of displacement/boost, or two turbos and 2.5" pipes. Each turbo/exhaust bank will only be moving half of the volume of air, so the smaller pipes will still be more capable of flowing efficiently on the car.
Also, on a turbo setup, you've got to consider the same concept of mass air flow and its relation to turbo sizing and spool characteristics. You're pushing one large turbo with the full displacement of the motor, or on a v setup, taking two small turbos each being spooled by half of the motor's volume of exhaust gasses. Once you start going for big power and going with larger turbines, the twin turbo setup will lag just as much, if not worse, than the single setup. This is why I believe a big single would be great for high hp apps even on the Z. The MAIN limiting factor is room to actually route the piping and parts involved (see above).
Just my thoughts on this, feel free to correct/debate them if needed.
Old Sep 7, 2007 | 06:13 AM
TENGAI's Avatar
TENGAI
Ok, so an "apples to apples" question. For a big SINGLE turbo Z, what would be the best exhaust setup? 4" single exhaust? Or the more common 3"? I'm assuming that most would say the bigger the better from reading this thread, but I'll throw it out there:
HAL - what did you guys run in terms of exhaust in order to break into the 1000whp+ zone? Big f'king turbo aside, how did you get it to flow it's exhaust gasses? Single exhaust or dual via reverse y-pipe?
Old Sep 7, 2007 | 06:20 AM
taurran's Avatar
taurran
Of course bigger is always better. No exhaust and just an open dump off the back of the turbine would be ideal if you didn't care about where the heat went or how loud it was.
I'd assume that they're running at least a 3.5"-4" pipe at those power levels. The problem running a turbo in front of the motor is that without major modification or a custom setup, you're going to run into space constraints when routing the exhaust. It sucks because on most of our single setups, EVERYTHING is mounted on the drivers side. This includes the steering rack/arm/knuckle, AC compressor, and AC lines that just get in the way when trying to route the exhaust.
If performance is the only thing you're after on a single turbo setup, a single exhaust that is as wide, short, and straight as possible is the best bet.
Old Sep 7, 2007 | 06:36 AM
TENGAI's Avatar
TENGAI
+1. That's pretty much what I was thinking too, but was looking for a shop's thoughts on it...
Off topic - looking forward to Sunday's results. What exhaust did you go with??? LOL.
Old Sep 7, 2007 | 07:10 AM
4SHIZZIL's Avatar
4SHIZZIL
So lets cut the VQ in half...we have an inline 3 (work with me here on my ideas...lol) which is half of what the Supra is. So if a supra is running 700 wheel on 5 in exhaust, cut that in half, that leaves 1.5 liter motor with 3 cylinders which equates to 2.5" exhaust for that cylinder bank. Per say.
So if we are thinking in terms of two Single exhaust set ups, anything over 2.5 is over kill? Now I know the exhaust side of the turbo is a factor, but in general my point of this thread is that there is no reason whatsoever in a VQ regardless of the setup to run a 3" dual exhaust, especially for trying to maximize effeciency.
Now the looks are great...and the sound is tremendous..but its not producing more power vs a single exhaust...thats what I am hearing.
Old Sep 7, 2007 | 07:23 AM
Blu_Blur's Avatar
Blu_Blur
Not sure if this has already been stated but you also have to consider the overall designs of the engine. In addition, I believe the Supra's engine is closed deck which supports boost better and makes power easier than an open deck engine such as the VQ.
Overall, exhausts are INCREDIBLY simple so if there are variances in the hp, it is because of other factors, not just some tubes and whether there are two of them or not.
Old Sep 7, 2007 | 07:35 AM
justusS's Avatar
justusS
rightright...I said usually. There's always exceptions. Typically, engine design and space limitation is going to dictate how the majority of setups will run. For the Z, a dual setup just makes sense.
That dyno sheet pretty much looks like a supra. Still building power all the way to redline. Don't get me wrong, it's a cool car....but I prefer a smaller twin setup that nails full boost within about 1000rpm of hammering it. If I wanted a power ramp like that, I would have just bought a supra =)...Still a nice car though.
Originally Posted by InjectedPerf
I don't feel this is 100% true. The reason Z guys usually run twin turbos is there is physically no room in the engine bay for a large single. We run single turbos on both our 350z and Toyota Supra. Z put down 1016rwhp and the Supra puts down the same. Both of these are through automatic transmissions.
[URL="https://my350z.com/forum/showthread.php?t=288149"]350z 1016rwhp Dyno Thread
Old Sep 7, 2007 | 07:51 AM
QuadCam's Avatar
QuadCam
Agreed but my question was on a 3.0L and a 3.5L not 1.8 to 10L.
it is still dependant on the intake manifold,heads, cams, valves, exhaust manifolds, turbine housings......there are just 2 many variables to ever make an even comparison.
Old Sep 7, 2007 | 07:57 AM
QuadCam's Avatar
QuadCam
One 5" has less volume than two 3" (3+3) being 6. I no I am being picky here, trust me...I just want to learn.....
actually, it would take 4 3" pipes to equal the same area as a single 6" pipe.
Pi*R^2.
(2) 3" pipes have the same effective area as a single 4.25" pipe.
Old Sep 7, 2007 | 08:32 AM
InjectedPerf's Avatar
InjectedPerf
Injected Performance
I understand. It is our drag car and you aren't going to make 1300+hp with small turbos. So any way you look at it with the HP we are shooting for it is going to have lag. There is always nitrous
This was the second day of tuning and we haven't strapped it on the dyno since then. There are still limitations to the power. Currently it is the intake manifold (I believe). This will spool the 47-88 much nicer than the Supra since it is a 4.2L compared to 2JZ 3.0L and stroked 2JZ 3.4L.
Old Sep 7, 2007 | 08:49 AM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
No. Again, from earlier.... "Dual 3" exhaust flows only slightly more than the supra-standard 4" single. For bigger-turbo supras 4.5 and 5" exhaust are more common now, both of which outflow dual 3"."
A single 4.5" flows more than dual 3" exhaust. As quadcam said, area=Pi*R^2
Tengai: The turbo outlet on our green 350Z is 5", which we neck down to a 4" pipe due to space constraints.
Old Sep 7, 2007 | 09:28 AM
4SHIZZIL's Avatar
4SHIZZIL
Cool, I see where things lie now. So I dont need to stress over big 3" (heavy) exhaust when I am only looking for 350-400RWHP. I just see guys/gals slap 3" dual on so fast,...then thinking ..."I need this for when I go FI." I just thought/think differently because of the simple fact of many single exhaust cars running similar HP levels. I put down 286RWHP with pretty much the stock exhaust on my G. HF CATS and Stillen Y pipe. I feel the backpressure, or the limit of extreme flow aided in producing such number corrected on a dyno dynamics.
The formula by quadcam was the ticket I was looking for. volume = r2 h
Old Sep 7, 2007 | 12:12 PM
QuadCam's Avatar
QuadCam
the formula for area of a circle is: Area = Pi x (radius)^2, where Pi is approx. 3.14159
Old Sep 7, 2007 | 04:11 PM
tig488's Avatar
tig488
its pretty cool seeing a straight 5" single exhaust on a BIG hp supra, kinda freakish looking.
Old Sep 14, 2007 | 07:16 AM
plumpzz's Avatar
plumpzz
the most important thing is that turbines make the most power when there is a large pressure differential across the turbine. High pressure on the compressor side, low pressure on the exhaust side. To minimize pressure, you want maximum velocity. That doesn't mean you want maximum volumetric flow- but usually maximum velocity and maximum volumetric flow are pretty close to each other in terms of piping radii especially in a low density gas..
Old Sep 14, 2007 | 07:35 AM
Old School's Avatar
Old School
Shift_Boost
The inline engine design will compliment running a single exhaust, and the VQ design is much more suited for a dual setup.
Physically look at both engines and see the difference on intake/exhaust for the two. Should make perfect sense when you see them.
Pretty much all the big number Z guys are running a twin turbo setup with dual exhaust while Supra guys are running a big single turbo with single exhaust.
Difference between an inline and V.
inline vs V. If you have one bank like the supra, you run one big pipe....but we have two banks on the Z (V6), so dual is the only way to go when going FI. If you really have a hard on for single, just make your Y pipe and the remaining pipe bigger. I'll stick with my dual exhaust.
Old Sep 14, 2007 | 02:22 PM
k3silk's Avatar
k3silk
Originally Posted by taurran
One turbo, better to run a single exhaust. Two turbos, better to run dual exhaust.
Turbo setups make power with no backpressure. NA setups make power with a small amount of backpressure. Superchargers fall somewhere inbetween.
Simple enough?
On a supra, even with a TT setup, the turbos are mounted on the same side of the motor so the exhaust can be merged even on a TT setup. On a 350z, a TT setup has one turbo on each side of the motor (exhaust manifold), so it's easier and better to run two pipes back.
However, I do think that dual 3" pipes are overkill for 95% of the built cars out there. The 350z community seems to be fond of doing everything overkill for the power levels achieved.
+1
Old Sep 14, 2007 | 04:55 PM
  #38
4SHIZZIL's Avatar
4SHIZZIL
Ok gentlemen..I think we have the VQ vs Inline turbo down. 3" dual maybe Overkill but if its boosted with twins it will provide the decent (more than decent) effeciency levels.
Now for N/A applications does the same apply? Is there a such thing as too much air flow out of the exhaust or lack of back pressure for a better word? Is there a relationship between intake pressure and exhaust pressure on the engine just as it relates to the two sides of a turbo? Alot of old muscle or track Z's and G's may run straight off the header. I can see a big V8 doing this because of the many valves/cylinders requiring massive amounts of air flow...but when you get into the 3.5 liter and below, does this still help or hurt the VQ?
Again thanks for putting up with my not so nube yet nube questions.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
