p300 code
Old Sep 8, 2007 | 05:31 AM
sam-z's Avatar
sam-z
Default p300 code
just woundering if my car will pass inspection with the p300 code multiple missfire every since the u-tec was installed.
Old Sep 8, 2007 | 05:43 AM
rcdash's Avatar
rcdash
Ummm, throw a CEL during start up and you usually fail. Need to get that fixed.
Old Sep 8, 2007 | 06:44 AM
sam-z's Avatar
sam-z
what would be causing it to missfire at warm up.
Old Sep 8, 2007 | 07:58 AM
rrmedicx's Avatar
rrmedicx
Stock block or built?
Old Sep 8, 2007 | 08:52 AM
sam-z's Avatar
sam-z
built block.
Old Sep 8, 2007 | 09:10 AM
Bolaz's Avatar
Bolaz
Just plug the code reader to it and it should clear the light for a few days. If you don't have one just go to autozone and ask them to let you borrow theirs
Old Sep 8, 2007 | 09:12 AM
rrmedicx's Avatar
rrmedicx
I just completed my build and I just started the engine for the first time last week and within a few minutes I got the same code. It means a misfire, and a lot of folks chimed in saying that once I get it tuned it "may" go away,secondly that cel lights are a standard with built engines,and to get used to it.
I don't particularly like these answers, but I guess once I get it tuned, I will find out. If you find out before, please don't hesitate to share your findings.
Not sure if it has anything to do with the UTEC, but I am looking into an aftermarket EM anyway down the line...maybe a VPRO or Haltech.
G/L
Old Sep 8, 2007 | 09:15 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Built motor with fcon and when I reset it it doesnt come on.
Old Sep 8, 2007 | 09:31 AM
sam-z's Avatar
sam-z
i had my motor tuned and i turned the light off.it only comes on when i let the motor warm up. when the coolant temp starts to rise.
Old Sep 8, 2007 | 09:32 AM
rrmedicx's Avatar
rrmedicx
So then does it go off after it warms up? or is it always on?
Old Sep 8, 2007 | 09:35 AM
eagletanggreen
Got Track!!!!!
ONce the light goes on it will stay on unless you reset it, with a scaner.
Old Sep 8, 2007 | 10:07 AM
sam-z's Avatar
sam-z
no the light stays on.i've turned it off several times.like i said the light comes on when the motor is warming up. the first start up of the day or when the car sits for awhile and the temps go down
Old Sep 8, 2007 | 10:12 AM
Jay'Z's Avatar
Jay'Z
Thats weird.. I reset it and it doesnt come back on for months.. The code sometimes comes on from my ****ty start ups with the 750cc inj.. The codes are normal and i really dont care..
Even when i get an inspection i dont care enough to reset it and the site still gave me my sticker..
Old Sep 8, 2007 | 10:23 AM
sam-z's Avatar
sam-z
In my area i can't pass inspection. they have to hook up a computer from your 0bd2 port and it goes straight to albany
Old Sep 8, 2007 | 10:26 AM
Jay'Z's Avatar
Jay'Z
^^ Oouch/Ur couch is ****ed!!
Old Sep 8, 2007 | 10:35 AM
UHATEIT's Avatar
UHATEIT
most built motors won't pass smog inspection anyways, not the "visual" portion at least
Old Sep 8, 2007 | 01:03 PM
fklentz's Avatar
fklentz
When I first had my built motor installed I was getting them frequently, the P0300 misfire code can be caused by a lot of various things, one of them being fuel pressure. Once I got the fuel line issues fixed it only came on when I filled the tank, I'd get it upon start up. It finally went away for about 5000 miles until I got a random one yesterday.
I say yours is fuel pressure related, the ECU has various tests it performs one of them being a warm up cycle, either the FP is too high or too low at some point durring the cycle. This is just a guess on the experience I had with my install.
If you do connect a code scanner, depending on what model, it can tell you if you have "Pending" ecu code and it will have freeze frame data that will indicate the specific conditions that caused the malfunction light to turn on.
Old Sep 10, 2007 | 08:10 AM
Vogtisslow's Avatar
Vogtisslow
Register the car for offroad use...
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
