GTM tension pulley install DIY...
Old Oct 24, 2007 | 05:06 PM
  #41
Barzten1's Avatar
Barzten1
Hows the new pulley setup working for everyone? Mine should be here in a couple days.
Old Oct 24, 2007 | 05:36 PM
  #42
MMC Racing's Avatar
MMC Racing
Good info, I need to get one of these.
Old Oct 24, 2007 | 05:42 PM
  #43
Nexx's Avatar
Nexx
works like a charm, saw 10psi with my 2.87
Old Nov 13, 2007 | 01:00 AM
  #44
Barzten1's Avatar
Barzten1
I recieved my pulley in the mail but it didnt come with a thread tap. Was it supposed to or do I need to get it elsewhere?
Old Nov 13, 2007 | 08:33 AM
  #45
THE TECH's Avatar
THE TECH
Nice write-up. One piece of advice that I can offer is to NEVER use the tap with a drill. It should be done by hand. You should run in it a few turns then reverse it out. Do this until you have it all the way through. You can really f*ck up the hole if you go to crazy with the drill.
Old Nov 13, 2007 | 10:22 AM
  #46
Biochem7's Avatar
Biochem7
Regular
why aren't people trying the new layout from Vortech. The holes are all predrilled. I don't know if you even need to purchase new pulleys?
Old Nov 13, 2007 | 02:33 PM
  #47
Triji's Avatar
Triji
The kit does not come with a tap, you can get one at almost any auto parts store... I got mine at pep-boys.
Old Nov 13, 2007 | 02:34 PM
  #48
Triji's Avatar
Triji
Yeah, great point... If you do use a drill use a corded drill and be very careful and patient with it.... You do need to drill a small amount at a time, back it out, and drill more in incriments... Do not attempt to go all the way thru in one attempt... You will "F" it up.
Old Nov 13, 2007 | 02:36 PM
  #49
Triji's Avatar
Triji
Mine has been running flawlessly since the install and I am hitting 9.2 - 9.6 PSI with the 3.12 pulley... I am going to try the 2.87 pulley when I get the time to install the utec and get a re-tune for it.
Old Nov 13, 2007 | 02:42 PM
  #50
Nexx's Avatar
Nexx
i screwed up the tap, just used a nut on the other side, worked like a charm.
Old Nov 13, 2007 | 02:57 PM
  #51
InZomniac's Avatar
InZomniac
9.6... Damn! I KNOW you had Noah build that motor you liar
Old Nov 13, 2007 | 03:10 PM
  #52
Nexx's Avatar
Nexx
+1 i thought 3.12 was suppose max out physically at 9psi.
Old Nov 13, 2007 | 05:01 PM
  #53
Triji's Avatar
Triji
Lol... nope no motor build Inzom... I think the 3.12 has a tad bit more in it than 9.... In the cooler weather at least and with a clean air filter... I remove / clean / oil my filter at least once a month now to keep her breathing nicely.
Old Nov 14, 2007 | 03:13 PM
  #54
G35asian's Avatar
G35asian
Right now I am hitting about 10 psi on average at redline with my 3.12 . Then again, I am revving to 7k instead of the stock 6600 so I get an extra psi up top.
Old Dec 4, 2007 | 04:00 AM
  #55
jpc350z's Avatar
jpc350z
So, how are you guy's that have the pulley mod liking it?? Any problems with it?
Old Dec 4, 2007 | 05:04 AM
  #56
moog's Avatar
moog
Mine should be arriving today. Hopefully have it installed by end of week.
Old Dec 4, 2007 | 09:19 AM
  #57
jpc350z's Avatar
jpc350z
What do you know about the Bando belt that comes with the kit? Better than a Gates?
Old Dec 4, 2007 | 10:13 AM
  #58
imalazeeass's Avatar
imalazeeass
ive only had to adjust my belt once after i had it installed... working nice
Old Dec 4, 2007 | 03:20 PM
  #59
moog's Avatar
moog
The Bando belt looks pretty hefty. The flat part is textured in a way to grip pretty well, and it says anti-static & heat resistant. On the Bando website it says its oil resistant as well, which is good.
Old Dec 4, 2007 | 03:26 PM
  #60
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
[QUOTE=moog]The Bando belt looks pretty hefty. The flat part is textured in a way to grip pretty well, and it says anti-static & heat resistant. On the Bando website it says its oil resistant as well, which is good.
Bando is also the oem belt supplier for honda,toyota,mitsubishi, very good quailty and longevity, by far the best
SAM
GT MOTORSPORTS
