GTM tension pulley install DIY...
Old Dec 5, 2007 | 05:19 AM
  #61
jpc350z's Avatar
jpc350z
[QUOTE=Sam@GTM]
Originally Posted by moog
The Bando belt looks pretty hefty. The flat part is textured in a way to grip pretty well, and it says anti-static & heat resistant. On the Bando website it says its oil resistant as well, which is good.
Bando is also the oem belt supplier for honda,toyota,mitsubishi, very good quailty and longevity, by far the best
SAM
GT MOTORSPORTS
SAM would you say it's at least equivalent to or better than a Gates which has been touted on this site as the belt to use with Vortech S/C'er..
Thanks
Old Dec 9, 2007 | 06:52 PM
  #62
moog's Avatar
moog
Got mine installed...need to tighten her up a bit more, but all my squeaks have disappeared. DIdn't quite install EXACTLy like Triji...i think my GTM pulley is a bit further from the 3.12 pulley.
The belt does slightly rub the little cam cover though, but not by much.
Old Dec 9, 2007 | 09:46 PM
  #63
Triji's Avatar
Triji
Great Job Moog!! Looks Great!!
You might be able to shave a tad off of the cam cover to eliminate that rubbing, I would watch that closely so you dont prematurley shred belts.
How was putting the belt on? Mine was pretty tough to get on, I have only tightened my belt once since install and she is still holding strong!
Great job!
Old Dec 11, 2007 | 05:54 AM
  #64
str8dum1's Avatar
str8dum1
pics on page 1 are red X's??
Old Dec 11, 2007 | 06:11 AM
  #65
moog's Avatar
moog
Does your belt make contact w/ the cam cover at all Triji/imalazeeass/G35asian?
Old Dec 11, 2007 | 12:18 PM
  #66
Triji's Avatar
Triji
No mine does not at all, that is why mine is closer to the jackshaft pulley, to get it to angle above the cam cover. I spent about 20 mins measuring / guaging placement so it would not rub there.
Old Dec 11, 2007 | 12:20 PM
  #67
Triji's Avatar
Triji
I'll try to re-upload the pics again from photobucket this time.
Old Dec 11, 2007 | 12:26 PM
  #68
moog's Avatar
moog
wierd...even w/o the GTM pulley, my other belt rubbed the very top portion of the cam cover...now it's about an inch down.
Old Dec 11, 2007 | 12:27 PM
  #69
imalazeeass's Avatar
imalazeeass
Yes, min did. I had to polish out the cover slightly where the belt is. Here are some pictures of mine:
Old Dec 11, 2007 | 12:52 PM
  #70
Triji's Avatar
Triji
Yup, look at the angle of your belt -vs- the angle of mine with the pulley a bit closer to the jackshaft pulley. This is with the 3.12 pulley. When I put the 2.87 on there will be a tad more space in there.
Old Dec 11, 2007 | 12:54 PM
  #71
Triji's Avatar
Triji
Pics, should now be fixed on page 1
Old Jan 7, 2008 | 04:52 PM
  #72
amai21's Avatar
amai21
I would like to order the pulley, but Iam not getting any response from GTM's email. Any other way of contacting them besides PM?
Old Jan 7, 2008 | 05:34 PM
  #73
moog's Avatar
moog
Call them, that's how I ordered
Old Jan 11, 2008 | 06:10 PM
  #74
amai21's Avatar
amai21
What size tap would I need?? It just dont make sense using a 10mm. Seems it would be too small??
Old Jan 11, 2008 | 06:18 PM
  #75
Triji's Avatar
Triji
It works, I used a 10mm x 1.25 tapper and the bolt threaded right in.
Old Jan 11, 2008 | 06:22 PM
  #76
moog's Avatar
moog
10mm is perfecto
Old Jan 12, 2008 | 03:34 AM
  #77
Barzten1's Avatar
Barzten1
Still havent installed mine. Bought a corded drill last week though. LOL....I've had the pulley for a couple months now.
Old Feb 17, 2008 | 03:03 PM
  #78
Barzten1's Avatar
Barzten1
About to start the GTM pulley install. Any do's or don't before we get started. Im a little nervous about it.
Old Feb 17, 2008 | 03:28 PM
  #79
moog's Avatar
moog
Just take your time lining it up to try and get clearance w/ the timing chain cover.
Old Feb 17, 2008 | 03:39 PM
  #80
Barzten1's Avatar
Barzten1
Damn got to go get a metric drill bit. Be back in a few
