GTM tension pulley install DIY...
Old Feb 17, 2008 | 04:21 PM
  #81
amai21's Avatar
amai21
my belt is rubbing on the cam cover... I dremeled it but still no luck...and ideas??
Old Feb 17, 2008 | 04:38 PM
  #82
Barzten1's Avatar
Barzten1
Couldnt find any 10mm drill bits. Should I use 1/4 or 5/16
Old Feb 17, 2008 | 07:01 PM
  #83
Triji's Avatar
Triji
You got a pep boys near you? that is where I got mine. Any auto store should have them... Use a 10mm... otherwise the tapper will not thread properly and your bolt will not fit right.
Old Feb 17, 2008 | 07:02 PM
  #84
Triji's Avatar
Triji
got any pics of your instal and what you are up against?
Old Feb 17, 2008 | 09:31 PM
  #85
Barzten1's Avatar
Barzten1
Originally Posted by Nexx
works like a charm, saw 10psi with my 2.87
What belt # are you using for the 2.87? I installed the pulley and now its slipping alot. I had minimal slippage before when it was really cold at night and now Im barely seeing 5lbs. I have it tightened all the way too.
Old Feb 17, 2008 | 09:43 PM
  #86
Barzten1's Avatar
Barzten1
Im using the 060935 belt with the 2.87. Also belt is slightly rubbing face of cam cover also.
Old Feb 18, 2008 | 01:58 AM
  #87
imalazeeass's Avatar
imalazeeass
sounds like your belt may be too long.. and u might want to polish the area on the cam cover
Old Feb 18, 2008 | 07:40 AM
  #88
Barzten1's Avatar
Barzten1
Any one have the proper belt # for the 2.87 please?
Old Feb 18, 2008 | 04:04 PM
  #89
booger's Avatar
booger
Barzten or Triji
Could one of you guys measure the pulley you added ? The diameter and width of it ? thanks !
Old Feb 18, 2008 | 04:10 PM
  #90
Nexx's Avatar
Nexx
barzten1, i used a 93" gates belt from napa i believe. its shorter than the belt they recommend, we had a nasty time getting it on. i saw 14psi at round 7000rpm, rofl. thats when we realized my rev limiter was set to 7200rpm. took it back down to 6800 just to be safe. now i see 12 to 12.5 psi at 6600rpm.
Old Feb 18, 2008 | 04:11 PM
  #91
Nexx's Avatar
Nexx
mine does the same thing. over time the belt has eaten away at it.
Old Feb 18, 2008 | 04:27 PM
  #92
Barzten1's Avatar
Barzten1
Crap. I just got done taking the blower off. I was taking it for a test run last night after installing the pulley and noticed my A/F guage wasnt reading or barely seeing 17. It would read when I gave it gas. The response was nice and crisp and I was going to jump on the highway and give it some love. I did already have an idea that there was a bad bearing in the blower because a week ago I started getting the rocks in the blower sound. Before I got on the highway I went to wot and hit 10psi which I usually wont see unless it 30 degrees out. Well I jump on the highway and for the first time ever I find myself next to a new Viper.......and he's calling. We get on it from about a 45 and Im right there with him for about 2 gears and then it felt like my belt was slipping. We back off and go again but this time it felt like my belt was slipping the whole way. Also I noticed a little oil spray on my windshield (I have a vented Seibon). I get home and my car is dripping oil like it got punched in the face. Car wont boost over 5lbs and it sounds like I have a bypass valve where the blower is. I pulled the blower and am going to send it for repair. Also gunna go to the bank tomarrow for a loan and probably build and go TT. I feel like Im letting my Vortech brothers down but this was something I planned after paying the car off which I just did. I was going to look into a T Trim but since Im putting in a new motor the TT install should be cake. Booger Ill go measure that pulley now. Also started a thread about running the car NA and had some questions about what to do with the vacuum line from the plenum to the bypass valve. Id love your help because I got the idea from you about running it without the blower. Also should I lower or raise my fuel pressure since Im going to be running rich as hell?
Old Feb 18, 2008 | 04:29 PM
  #93
Barzten1's Avatar
Barzten1
Booger I was never good with the tape measure but I think its 2" diameter on the pulley.
Old Feb 18, 2008 | 04:37 PM
  #94
clifftrail's Avatar
clifftrail
Barzten,
If your going to go TT in the future, I'd be interested in the 2.87 pulley and I'm local so let me know if you ever what to sell it. Thanks.
Old Feb 18, 2008 | 05:01 PM
  #95
Barzten1's Avatar
Barzten1
I have all 3 pulleys 6 filters including a K&N long filter thats never been used and several belts. After I sell the kit Ill sell the accessories. If you haven't upgraded to the K&N long filter its a very nice difference. You'll definately be happy with it. If you havent heard about it do a search. I've been at it all day and need some down time but Ill try to find the thread on it later and bump this thread with the link.
Old Feb 18, 2008 | 05:03 PM
  #96
Barzten1's Avatar
Barzten1
ohhh crap your in Abq. Have we met? Wish I would have met you before I sent the blower in with the 2.87. You would have smiled GREATLY!
Old Feb 18, 2008 | 05:09 PM
  #97
Triji's Avatar
Triji
Originally Posted by booger
Barzten or Triji
Booger,
It measures 2" in Dia and 1" in width.
Old Feb 18, 2008 | 05:10 PM
  #98
Barzten1's Avatar
Barzten1
Ooops forgot about the width. I feel better with you getting the dimentions from Triji anyways.
Old Feb 18, 2008 | 05:17 PM
  #99
clifftrail's Avatar
clifftrail
Barz,
Can't run the long filter, I have a G and I'm not going to cut a hole in the support so I'm going to stick with the short cone. I'm pretty sure we've never met, I don't recall seeing a Z with a Seibon hood around either. I'm in the NE area and work on base.
Old Feb 18, 2008 | 05:34 PM
  #100
Barzten1's Avatar
Barzten1
Yeah I pretty much dwell on the west side. Have you heard of Racingsouthwest.com? Very cool group of people Ive been a part of for a couple years. We have meets and runs. You should check it out.
